Cutting guide for straight cut on a scroolsaw
  • Cutting guide for straight cut on a scroolsaw
    Does that guide exist, for cutting straight or with an angle. I have an excalibur saw.
    I am figuring doing one with wood.
    Thanks
    planeur
    Clamp a straight edge to the table and give it a try. It does not work well as you will discover. The blade will wander.
    The right to buy weapons is the right to be free.
    -- A E van Vogt
    Weapon Shops of Isher
      Thanks !
      And I hope you will not get hurt with the right to be free.....🙄👎
        Like Bob said clamp a straight edge to the table and adjust it to compensate for the blade drift. There are some blades that have no or very little drift. Like the Olson PGT series it also seems to me that the Pegas MGT 3 or larger cut very straight.
          Merci Rolf , I use Pegas blade but not that kind, interesting what they say about it.
          I will try them.
          Have a good day
          planeur
            Cutting a straight line I get it started then plant my thumb at the side of the piece and use that to stabilize the cutting path, a bit like the pin you would use on a bandsaw when resawing old style.
            https://www.etsy.com/shop/BeasleyTurnings
            Stabilized blanks and more
