Saw won't start! (EX-16
  • Saw won't start! (EX-16
    I have an Excalibur EX-16 that is about ten years old. Recently the saw at times would be slow to start when flipping the switch, and now will only start every 8-10 times (and after waiting up to 10 seconds at that). Thinking it was the switch, I took the top black plastic casing off, and checked it out. Everything looked fine. But it may not be the switch - I know VERY little about the mechanics of the saw. Sometimes the saw arm sticks in the "Up blade position"; though I understand the bearings are self-lubricating (according to the manual). I don't know what to do, but do not want to go through the stress of finding $ for a new saw if it's only a single part or so. HELP!!!! Any advice would be greatly appreciated.
    The best advice I can give you is to call Seyco and ask for Ray.
    https://www.seyco.com/
      Don't believe that self lubricating stuff about these saws. I just rebuilt an EX 21 for a friend, every one of the bearings in it were dry the main bearing on the Pitman arm was actually rusty.
      I have the EX-16 as my second saw. Bought it used. I took it apart lubricated every bearing the saw with the exception of the motor.
      Unplug the saw.!
      Before you go nuts two things I would do. 1. The end of the motor has a small hole in the middle of it. Put an ordinary screwdriver into the hole turn it the shaft should rotate easily. There are strong magnets in the motor so it will jump a bit. If it is hard to turn then there is a seized bearing.
      2. There is a cover on the opposite side of the motor, remove the three socket head cap screws, they may be very tight. The cap screws are metric.
      This will remove the cover and you can see the pitman arm and you can rotate things from there also.
      The third picture is of the "self lubricating" bearing that was in my friends saw.
        Thanks Rolf! What do you personally use to lube the bearings?
          I used white lithium grease. It was what I had on hand and used it on many other things. I am not sure if that it is the best or not.
          Did you try turning it?
            To me since it won't turn on it does not sound like a bearing issue. Are you using a foot switch? If so try it without the foot switch. They have been know to fail. Frankly, I am thinking it is either a motor or speed control issue. Does the problem exist at low speed, mid range and high speed? If you decide to work on the bearings, when I rebuilt a Dewalt many years back I used a synthetic grease. It is available at most hardware store, auto supply and even Walmart in the automotive section.
              Scott the reason I suggest checking if the saw is binding. It is a simple check especially with a screw driver in the end of the motor. That is what my friends saw was doing depending on where it stopped and the motor had enough torque to start it again from that position. Obviously if it all turns freely then the next step would be electrical. But at 10 years old based on what I have seen in my short experience with these saws lubrication or lack thereof has been very prominent.
              • Linda In Phoenix
                Reply to Shrink wrap systems
                by Linda In Phoenix
                What thickness of film seems to work the best for puzzles?
                The bags seem easier on the surface.
                But the film seems like it is more versatile on size variations.
                Today, 03:24 PM
                Reply to Bruce, the one on probation
                Regulations are 150 square feet, this will be 144 square feet so we are good. He’s making it that size Since the sheets are 4’ wide. And the Shelves need to be 4” above my head!! It will be very specific.
                Today, 10:32 AM
              • Sandy Oaks
                by Sandy Oaks
                As a framer, we have a shrinker wrapper at ArtCrafters. Very simple. Film on a roller, sealer attached, just roll off enough film, seal the film, insert object, seal other end and shrink with a heat gum. We also use Uline as a source. Not sure where our unit can from as it was with the shop when...
                Today, 09:46 AM
              • NC Scroller
                by NC Scroller
                I would make the shed 1" less than the size permits are required for. THERE IS NO SUCH THING AS TOO MUCH SPACE....
                Today, 07:42 AM
              • NC Scroller
                by NC Scroller
                I shrink wrap all my puzzles. It is the best method I have found. I do not use a cardboard backer as some do. I use shrink wrap bags that I get from Amazon or Ebay. 8" x 12" will fit 95% of the puzzles I make.
                To use the bags you will need a sealer. I have one very similar...
                Today, 07:39 AM
