Seyco Dust Collector
  • Seyco Dust Collector
    I set up the Pegas scroll saw at ArtCrafters. Since this is an art gallery, we couldn't have a lot of dust floating around. I purchased a Seyco Dust Collector to add to the saw. I will be using the saw for test drives, demos and lessons. I connected it to the foot switch so it would only be on when the saw is running. I used a couple of extra zip ties to hold the hoses in place. After some use, I will let everyone know how it works.
    Denny
    ArtCrafters in Dayton, TN
    That saw sure is clean. Hang those pictures as a model for cleanliness!
      Jim, we will wait and see if the Seyco does its job of collecting dust.
      Denny
        Nice setup keep us posted of how it works out, RJ
        Life Begins @ 190 MPH
          Thanks RJ. I did give it a trial with a little project. A little dust on the table, but most in the jar.
          Denny
            How noisy is it Denny?
              Rolf, If you ever used a mini vac like the Dust Buster, about the same.
              Denny
                On Seyco's website it says 62 dB. If I remember correctly a Festool vacuum says 62 dB on the lowest setting.
                Kevin
                www.KevsKrafts.com
                  Thank you for giving us some first hand experience to help see it's potential value. Keep us posted the more you use it!
                  Linda at www.ArtIngrained.com
                    Thanks Linda. Hopefully use it more next week.
                    Denny
                      Denny, Sure glad you posted this. I have been looking at the Seyco Dust Collector or awhile. My Question is how does it do on the top of the table and wood. I have a solution for the bottom on my Seyco saw. I am looking for a solution to the sawdust on top. PS how do you like the Pegas saw.. I have the Pegas clamps on my Seyco and like it much better than the original clamps.
                      The other John A. Nelson
                      johnsworkshop.com
                      sigpic
                        Hi John. There is no vacuum on the top, just under the table. After scrolling, I leave the vacuum on and push the dust through the table holes. The hose is attached with a strong magnet. Maybe it could be attached to the upper arm.
                        Denny
                          I f you want to gather the dust on top you would have to add another suction tube on top. Hawk dust collection 3.jpg
                            So the two you show are sucking, Not blowing.. what are they hooked up to?
                            johnsworkshop.com
                            sigpic
                              The two nozzles are attached to a PVC manifold, with a trap in it to catch the small parts that you want to keep that get sucked up.
                              I have a Festool vac attached running at low speed. It comes on with my foot pedal along with the saw. works great. I don;t use my blower at all.
