DeWalt Stopped Running
  • DeWalt Stopped Running
    The DeWalt at our office quit running. I swapped out the switch for another switch we have for a Delta, and it still doesn't run. Any thoughts?
    Best Regards,
    Bob Duncan
    Technical Editor, Woodworking/DIY
    www.WoodCarvingIllustrated.com
    www.FoxChapelPublishing.com
    www.ScrollSawer.com
    Did you check the fuse and brushes?
    Carole
      Checked the brushes, but didn't think to check the fuse. That's the culprit. Thanks!
      www.ScrollSawer.com
        I was going to ask the obvious, but seems you found the demon.
          My next question is why did it blow the fuse?
            I am with Rolf. While fuses and circuit breakers can fail, it is pretty rare. Blowing fuses typically points to a bigger issue in the motor, switch, or the wiring. It would be interesting to see if you reinstalled the switch you removed to see if it blows again
              Loose connections are a chronic source for trouble. Unfortunately they are not always all that obvious and may well have been addressed during the course of troubleshooting, switch replacement etc..
              cwmagee
              aka Fibber
              Producer of fancy firewood​
