New Pegas Blade Clamps for Seyco, Ex and Clones
  • New Pegas Blade Clamps for Seyco, Ex and Clones
    So, for those of you that got the latest version of SSW&C, what did you think about the advertisement for the new Pegas replacement clamps for the EX (and clones) and Seyco saws?
    Get a peek from a German Vendor here: https://www.dictum.com/en/tools/wood...r-complete-set
    I'd be interested in more info and seeing what's going on with that nut on the opposite side of the thumb screw ---used to seeing a set screw over there so I'm baffled what or how that side is set up on the Pegas one. And it says it's lighter, which is vague. What does it weigh and what does ours weigh by comparison? I can't see how it could get much lighter and have any true effect. Interesting though. And what materials are they made from? My biggest issue with my clamps are that they are made from aluminum and the set screws are hardened steel. Taking a blade in and out thousands of times during the year, the set screw tends to wear out the threads in the aluminum clamp holder. Then set screws won't stay tight, and blades come loose. That area would be the best area to see improvement in the manufacturing of.
    Linda at www.ArtIngrained.com
      Yep, have that clamp knob go directly into Aluminum was a very bad design. The Pegas clamps supposed to be 40% lighter, and that is significant (because, I'm using the Hegner knob, which adds a little more weight). Maybe they have a steel sleeve or something else. I'm hoping that issue is addressed.
      My theory . . . . For a few years, Pegas has been selling their own branded version of the EX, but under the Pegas name. Like Seyco, they have probably had some complaints about the lever flying up on it's own after a little wear, and a few other issues. So, they developed a solution for their own saw, and thought this might be an easy sell for the other saws where this is also applicable. Well, that is my theory anyway.
      In any case, if it is priced within reach, I'll probably give it a go since my top lever is starting to fly up more often, and needing a replacement anyhow.
      ----Randy
        If the aluminum is getting stripped out on the stock clamps I would find a local machinist and have them put a helicoil in it. What is the tread in the clamp? Is it metric or inch?
        Once done you have steel on steel threads.
          Metric on the Excalibur. That's definitely a thought on the helicoil. I kept my last clamps that were worn beyond help. I'll look into that possiblity. Thanks.
            My EX is just 2 years old. Got it January 2016. It came with an extra lever in the factory sealed package. I have a lot of hours on the EX and have yet to have an issue. My biggest issue with the EX clamping is getting hockey sticks from the bottom blade holder especially on smaller blades. Just can't seem to get rid of them. I wonder if this new holder might help.
              This may be worth the investment
              https://www.amazon.com/s/?ie=UTF8&ke...l_2b139t6hgv_e
                The bottom clamp of the EX is prone to separating, if you tighten the bottom knob to much (something I'm guilty of).
                I have thought of taking the clamps to my machinist buddies and see if they can duplicate them in HS steel. But I'm afraid that the extra weight on the ends of those little arms will cause problems.
                I've been keeping an extra bottom clamp on hand, but now that models are changing I might get a couple more.
                Tony
                  NC scroller -- Ray at Seyco has reminded me more than once that hockey puck blades mean you need to adjust the set screw (opposite the thumb screw). If the crook of the hockey stick points to the thumb screw, turn the set screw out slightly and try again. And vice versa if it the bend points the other way. Over time the little set screw can shift a little. Once it's in perfect position, many people use a little loctite on it (the heatable kind).
                    I'm at the point of using the Loctite. Hope it works. Seems like my blades are always working loose.
                    My Excalibur is just two years old. Never a minutes problem till these blades started working loose. Changed out the clamps but no relief. Looking forward to hearing from anyone who is using the new clamps.
                    Tracy
                    Nicholasville, KY
                    ​Excalibur 21"
                    www.sawdustgallery.com
                      Tracy, it sounds like your set screw needs adjustment. The best way to do this is to
                      1. Back the set screw completely into the clamp (counter clockwise, the direction you would go if you wanted to remove the set screw)
                      2. Put a penny or something flat into the clamp, then use the clamp knob to push the penny against the far side
                      3. Then turn the set screw until it touches the penny. (At this point the set screw is even with the edge of the clamp)
                      4. Turn the Clamp knob to remove the penny
                      5. Turn the set screw 1/2 turn further into the clamp, which will make it just proud of the side of the clamp.
                      If you do that on the top and the bottom, you will have both set screws just barely protruding into the clamp. (they call this proud)
                      In case you have done this, but you set screw keeps moving on you, Loctite is your best bet to keep them in the perfect position.
                      It is also possible that the tip of you clamp knob or the end of the set screw is worn and is no longer flat.
                        Thanks, I changed out the tips with new ones and adjusted the set screws. Still working loose. I have applied the Loctite but have not used the saw since. Been sick and not able to get into the shop. Hope to try it out soon.
                        Tracy
                        Nicholasville, KY
                        ​Excalibur 21"
                          I'm working with Pegas to try to get a sample to check out. They said as soon as they are available, they'll send me a set.
                          PS. If you also check out the Pegas site, they've got what they call a "Scroll saw band saw" that I'm also trying to get a sample to review. That tool looks revolutionary.
                          www.GrobetUSA.com
                            That Scroll Saw Band Saw, is not something I would buy, well at least it would be far down on my list, but I sure see a ton of possibilities with it. Okay, I might even move it up a little on my list.....
                              Pegas's use of the slotted rollers is very much like the Carter guide addition for the 1/8 - 1/4 blades. Pegas does use them top and bottom which is different and probably adds more stability to the blade.
                              . So if you have a 14 inch band saw the Carter option is worth a shot. I already have the Carter roller guides on my saw so for me it would be about an $80 upgrade.
                              http://www.carterproducts.com/band-s...saw-stabilizer
