Blade Use
This is a sticky topic.
  • Blade Use
    Here's another table from Mike D.
    www.GrobetUSA.com
    hi ,could you show your work with spiral blades? /on what projects should they be used,?
      Spiral blades can be used on whatever the operator fels comfortable using them on. For me, only once in a while on some of the most tedious portrait style cuttings, or for widening a veining line already cut with a flat blade. Also on things to wide to turn all the way around because of saw throat size. I never use spirals on anything that exact lines following a pattern are critical. I am much better cutting with a flat blade, especially long straight lines. Dale
        spiral blade
        I love the spiral blade, I use them on most of my work. Here is one of my early works, the face and letters are cut with spiral blade.
          Hi . I just tried to use a #2 blade to cut out some small letters out of 3/4 " pine .It 's for a sign for a woman ,who has developed a fudge to use with wine . It is a small sign to place on her table only about 9" x 11 " . It is a wine bootle , 2 glasses with some grapes and the lettering below . Anyway, the blade seemed to have a mind of it's own and I could almost twist it 180 degrees before it would come back on track only cut a bit when I changed to a # 5 . I also changed the top blade holder screw as the tension would slip . I bought a new one for my dewalt . I only needed to replace the small rotating end . They will only sell the whole screw at a cost of about $10.00 in Vancouver B.C. Is there any way one can get Dewalt or Black and Decker to just supply the end ? The new screw worked better and I believe the blade was too small for the wood thickness .
          Thanks . Roger
            Blades with a mind of their own.
            I was pleased to see that I am not the only one that suffers from blades with a mind of there own. I cut a lot of puzzle pieces with tight curls. The blade follows the curve as I go into it but when I try to turn and come back out it takes off in an uncontrollable manner. It has been suggested that this might be due to the burr on the right side of some blades.
            I have been experimenting with the new #5 FD ultra reverse blades and I have found that I have better control.
            Oldjohnevans
              Great chart
              As a 'new scroller', I've been looking for such a chart that generally summarises bladetype/usage. .... Good one !!.... Thanks.
              ... Ray.
              " Perfect Speed is... Being there. "
              ---- Chiang Seagull
                This was my first (sucesful) attempt with spiral blades. They have their use. Not for strait clean lines, but the effect they have on this type of cutting can not be achieved with strait blades.
                </IMG>
                www.pajarostudiowns.com
                Excalibur EX-21 fanatic
                One of the Chosen few
                  Nice cutting Pete, and the frame is a great finishing touch.
                  Alan.
                  Alan and Rafi.
                  In our house, if you have to bend over to pet a dog it ain't a real dog!
                    This chart will make a good reference when unsure thanks
                    Ron
                    I won,t tell you what I don't know
                    http://www.scrollsawer.com/gallery/s...0/ppuser/13539
                      I can not seem to open this file. Am i the only one with this problem?
                      My Gallery
                        so far I have only had limited use for spirals. I had one ornament that I was trying to cut with a flat blade and was having problems in one area so I tired a spiral and was able to do that spot, but when I tried it on other places it didn't do so well so I went back to the flat blades.
                        Bill
                        I have an RBI Hawk 220-3 VS
                        Visit my Gallery
                        and website www.billswoodntreasures.com
                          Thanks for the blade chart it will really help me since I am still pretty much a newbie here ...
                          Ya'all Be Fun and Have Safe ... ~Kindlyoldpoop~
                          "I'm A Hard Dog To Keep Under The Porch"
                            That's a nice chart Bob. Thanks for the copy.
                            -- Rick --
                              Thanks for the blade chart. Being new to scroll sawing, I find choosing the correct blade for the job is the hardest thing for me. I have the worst time when cutting out a project that calls for a stacked board cut.
                              • Daddy's scroller
                                Reply to Oranment exchange
                                by Daddy's scroller
                                Scott I also received my package from you. Thank you so much. I like also like to see what Santa brought me. My tree has nothing on it but all the homemade ornaments I have received over the years....
                                Today, 07:17 PM
                              • Daddy's scroller
                                by Daddy's scroller
                                Thank you Jim I got my package from you today. That was a great idea. It's already on my tree
                                Today, 07:14 PM
                              • Jim Finn
                                Reply to Train set
                                by Jim Finn
                                Today, we made our December delivery of toys to our local children's hospital, Ronald McDonald House, and The Salvation Army of 1,912 toys. Including 27 of these trains.That makes a total of 4,112 for 2019. About a thousand less than our best years but not too shabby. (Two of our main club contributors...
                                Today, 06:06 PM
                              • Jim McDonald
                                by Jim McDonald
                                Scott, thanks a bunch for a great surprise.
                                Today, 05:46 PM
                                I am sorry that I did not participate the last few years. I am like a little kid waiting for the mailman every day waiting to see what Santa sent me.
                                Dave Thank you so much for organizing this.
                                Today, 03:00 PM
