I was just wondering if anyone has used the Easy-Lift system for the 788. Right now I've got a piece of wood that I stick in there to hold up the upper arm. I haven't had any real problems. But it has gotten in my way when threading a hole deep in the pattern. Does it work? Is it easy to use? Is it worth the $20 ?
DeWalt 788 Easy-Lift Sytem?
Rock and Scroll
My Gallery
My Website
Featherwood WoodcraftsTags: None
Hello Jim, I personally don't have one nor ever used one, but feed back from those who do have always been positive It's a good concept and I think a fair price.
I top feed with my Dewalt and really have no trouble raising the arm with my left hand and threading the blade with my right. I guess its what you get used to.
I'd rather spend the $20.00 on wood,blades,patterns.............Last edited by ozarkhillbilly; 03-05-2007, 06:33 AM.Bill
DeWalt 788
aut viam inveniam aut faciam
This is probably a dumb question, but....
do you raise the upper arm and leave the blade in the top clamp, or do you remove the blade from both clamps, raise the arm out of the way, then thread the blade? I haven't been raising the arm at all, I just remove the blade and rethread with the upper arm down.Joel
I have the easy lift system and think it's great. The only thing I noticed with it is that I have to hold the arm down a bit prior to tightening the blade, but that's probably just because of how I have the tension adjusted on it. I put the blade in on top, tighten the bottom, then go and retighten the top, holding the arm down - then do the tension , which I find is perfect around 31/2 or 4.Janette
www.square-designs.com
Joel, if bottom feeding, release the top of the blade, raise the upper arm, and then thread the top of the blade thru the hole in the bottom of the wood. Of course, you have to hold the wood as high as possible to be able to see under it to find the holes. Then reclamp. No, it's not a dumb question. If you don't ask, you don't learn.
However, I'm with Bill regarding top feeding. I don't really see any value to this if use his method. If I was still bottom feeding, I would probably consider the Jim Dandy.Last edited by Minnesota scroller; 03-04-2007, 12:32 PM.
Originally posted by JoelMI top feed, but I've never raised the arm. I just remove the blade, reposition the wood and drop the blade through another hole. I suppose if I did raise the arm there would be more room. I'll have to give it a try.Last edited by Minnesota scroller; 03-04-2007, 06:12 PM.
Wow, I never even considered bottom feeding. I'll have to give that a go and see how it works. When I had my old Taiwanees saw, it had a blade clamp on the bottom and an easy-jig for the top, so I've always been accustomed to top feeding. Picture that. I would pull the blade clampp from the bottom, position mypiece on the table, at an angle, push the blade up through the table and into the piece, (all this with my neck at a 98 degree angle,ouch). then lock the top with the quick-jig. Hey, not for nothing, I did some pretty incredible work like that, (what was I thinking. Give me my 788 any day).
So I guess I'll have to try that bottom feeding thing. Still, will I have to crane my neck to lock the bottom clamp? Thanks for the imput, all.Jim
Rock and Scroll
My Gallery
My Website
I'm a bottom feeder and I have the easy-lift attached to my saw. I couldn't imagine doing without it. Cut, right hand moves left to detension, unscrew the blade, lift the arm, locate the next hole and feed the blade through. Screw the blade down, right hand pushes the top down and retensions the blade, then hits the power button on the top. It can become a real rhythm there after a while.
Jimsawyer.. a bottomfeeder feeds the blade UP through the wood, and reclamping at the top clamp.And as unixpro stated, you do in fact get into a rhythm, and its even hard to explain, but a 6 second blade change from hole to hole bottom feeding is quick enough for me,thats why Im still a bottomfeeder.Honest, I has nothing to do with my thick hard skull!!! DaleDale w/ yella saws
Duh, sorry there. Momentary lapse of reason. I got my terms turned around. I've been a bottom feeder for 17 years. What I meant to say was That I had never thought of top feeding. Although, I do have a problem. Because I do alot of inlay work, I have to put a couple of pieces of masking tape over over the blade hole to make a sort of zero clearance set-up. Otherwise I can loose some very small pieces. This leaves me with a very small hole to thread down into. However, the next time I do anything fretted, I'm going to try top feeding.Jim
Rock and Scroll
My Gallery
My Website
I'm a bottom feeder with an Easy-Lift too. I got mine a week after I bought my saw. When I'm not using it, I put a piece of 2X4 under the arm in the up position. It takes some strain off the spring, so I hope it will last longer.Fred
Reply to Harbor Fraughtby RolfI did not read the fine print, actually not that fine. when I went to buy my new compressor for 25% off (not). That would have been nice, but I am still happy with my purchase. Although I have not used it yet as my garage is rather cold.
7 deg this morning 50's tomorrow-
Today, 09:22 AM -
Reply to Harbor Fraughtby JimernSome manufacturers will restrict items for resale to a certain price or basement price. And in some cases will only sell with the agreement of no discounts allowed.
And then there is margin, the retailer needs to make a certain amount of money on all sales.-
Today, 09:20 AM -
by RolfHave you had big temperature swings in the shop? My first thought is something binding. I fix all of my own stuff and don't hesitate to take things apart to try and isolate where the issue is.
That said at only two years old I would contact Denny and see if he can direct you to a Pegas tech center....-
Today, 09:15 AM -
by NC ScrollerWelcome. Could be a number of things. I would call Denny at Art Crafters of Dayton or Ray at Seyco. Both numbers can be found on the internet.
Today, 06:47 AM -
