Does anyone know if an airbrush compressor would put out enough velocity to blow dust out of fretwork projects? I've been using canned air, but it doesn't have much output and is only good for short bursts. I don't relish the idea of running outside and turning on the big compressor for just a small thing.
Airbrush Compressor?
Air Compressors
Just about any air brush compressor should work. They go up to about 50psi. Here is one place to buy small compressors. You might want to invest in one a little bigger than an air brush compressor as they are rather handy for a lot of things. (http://www.ares-server.com/Ares/Ares.asp.) The address is for Micro Mark. There are others, Iwata, Badger etc. Another address, (http://www.dixieart.com/), has air compressors.Buzz
Mike you could try Harbor Freight http://ww2.harborfreight.com/cpi/cta...emnumber=93657Daryl S. Walters Psycotic scroller with a DeWalt 788
Mike:
From your post, I presume you have a big compressor already, correct?
Have you considered just a portable air tank? An example of what I am talking about is in this link, which is only for clarity:
http://www.amazon.com/Campbell-Hausf.../dp/B0000CBJFA
I know other makers have similar products, which you should be able to find locally.
Phil
For about the same money you could buy a nail gun compressor. Higher pressure and you can use brad nailers etc. I picked up a used one for about $30 twin tank that I keep in the basement. Watch for sales at your local box stores.Rolf
Phil, that is a great idea. It 's much less money and will definitely do the job. Thank you very, very much.
This is what this message board is all about - members helping members without expecting anything in return, except assistance when they need it.
I just made a call to a local store and found a 5 gallon air tank for $22.95.Last edited by Minnesota scroller; 02-18-2007, 10:33 AM.
Mike,
If you can, get the 10 gallon one. they are not much more expensive and you charge them half the time
Also don't forget that you'll need to make yourself an adaptor to load the tank with the other compressor: 2 quick connect male adaptors with a male to male threaded adaptor in between, connecting them back to back does the trick for me. It let's me keep the regular quick connectors for the accessories on both of the hose ends. You just need to disconnect both at the same time in order not to deplete the tank (or to install shut-off valves, but that is a luxury not a requirement)
If you need further details, let me know and I'll try to clarify.
Regards,
Marcelhttp://marleb.com
Reply to Who has Been Vaccinated ?Can't get mine yet in Arizona, although I'd love to. Don't have enough vaccines here, so we are still focused on high exposure 'essential workers' and people over 75. I have a sister in assisted living with hospice people and care givers that come and go everyday...they still haven't received the...
Today, 01:43 PM -
Reply to Who has Been Vaccinated ?by Sandy OaksWe have not. A visit to the doctor and he stated that once sick with covid, the antibodies are active in the body.
Today, 01:42 PM -
Reply to More toysAwesome work, and really great cause!
Today, 01:39 PM -
Reply to More toysby wjbclocks1Those are really different. Thanks for sharing....
Today, 12:47 PM -
by Quartz43My wife and I got vaccinated this morning. I had worried that there would be long lines. But, the state of Indiana seems to have gotten it right. We went online 10 days ago and scheduled an bbc.co appointment. We got there as nd no line and went thru the check in, got our shots, waited 15 minutes...
Today, 12:08 PM -
