Need help/info on scroll saw
  • Need help/info on scroll saw
    I am new to this and was recently given a Power Craft scoll saw,sold by the old Monkey Wards by a friend's father. The model no# is 15FD23568. It is an old unit in good shape, runs well an appears to cast iron and heavy, with a large electric motor located underneath the saw. My question is the type of blades this unit should take. I have seen the current blades on the market today "pin style or flat end", which do not fit. This unit appears to take a blade that would require something close to 6 inches long with a size 10 hole thru each end of the blade, to fit the upper an lower shafts that have allen head screw with a bracket that screws into the shaft to hold the blade in place. Our blades available for this saw any longer ? Or does it need to head to the junkyard.
    SEG3, go to www.scrollsaws.com. Rick may be able to help you.
    Mick, - Delta P-20
