Drill Press Question
  • Drill Press Question
    I am curious about the minimum size drill press to buy. I will mainly be using it to drill holes for fret work but want to also be able to use forstner bits to drill for clock/picture inserts and use forstner bits the size of votive candle holders (to make nice candle holders).
    I also like to make pens so I will be drilling pen blanKs as well.
    Tell me what kind of drill press you are using and what you have been able to accomplish with it.
    Thanks,
    Dan
    I have a 14" delta that I am mostly happy with. What you should be looking for are...
    1. Do you want a free standing for bench.
    2. What is the range and number of speeds.
    3. How much quill travel does it have (distance the arm moves the drill up and down).
    4. The distance from the column to the check (mine is 14").
    These are the factors you should consider and your intended uses wii dictate what you should buy. To drill holes in pen blanks you may not need much quill travel, but you will need a good jig to hold the pen vetically.
    My only real problem with my delta is that I don't like the on and off switch. They are not very smooth working at all.
    Dan
      For most of my scrolling work, I use a Dremel-dril press, which works well for scrolling and small holes, but not much else <GRIN>
      So I can't help you...sorry!
      Bob Duncan
      Technical Editor
        Dan.
        The best thing I can sugget is getting the biggest drill press with as many speeds as you can afford. I too make hundreds of pens and not only do I drill out all my own blanks but I also use my 16 speed drill press for pressing the hardware into every one of them. That saves buying an expensive pen press.
        Eventually you will want to use some big forstner bits and the slowest speed will not only save your bits from heating and loosing their temper but you will have the power to do the job. High speeds don't take much power but low speeds do.
        Then for the tiny numbered bits you need the highest speeds. All the speeds in between will become usefull for various jobs. For example, I find medium speed is best for me for my buffing wheel that I use my drill press for.
        I got mine used from a newspaper adveritsement about 10 years ago. It cost half the price of a new one and turned out to be an excellent investment.
        W.Y.
          Reply to Rikon Air Cleaner
          I wish Bruce a speedy recovery. If his recovery is similar as that of a friend he will be up and around in no time at all. My friends is over weight and had both knees done 5 days apart. Physical therapy helpd alot.
          Today, 08:47 PM
        • Tango
          Reply to rbi Hawk scroll saw spring
          by Tango
          I had to replace the motor on my Hawk that we purchased new in 2002. I just called up Hawk & they had me send them my motor the power switch. He needed to collaborate the new motor and to my power switch. The new motor was sent back with in the week. I did this back in 2018 and it was a little...
          Today, 04:06 PM
        • surrealdreams
          by surrealdreams
          I've tried label paper as well. It peels off reasonably well, although different brands will probably perform differently. When it doesn't come off easily, I have a little heat gun that makes release quickly. When I have used 3M spray adhesive and left it on for too long, a hair dryer or heat gun...
          Today, 02:47 PM
        • Scroll Saw Bob
          by Scroll Saw Bob
          Rolf, What is the voltage, H.P., and rpm on the motor on your G4?
          Today, 01:06 PM
        • planeur
          by planeur
          It is me again....😉 with an other try which I think is the good one.
          Lets compare :
          the original stained glass before it broke
          the same with broken glass
          my first work to fill the hole
          or
          Today, 11:34 AM
