I was using my Dremel 1680 today and wasn't using my foot switch because it's hooked up to my Dewalt. I pushed the on button and nothing. It was plugged in tight and the strip was working. I tried to turn it on and off a couple more times and finally I heard a slight hum coming from somewhere inside the saw. I toggled the switch a couple more times and then it started up. Any ideas? Thanks.
Dremel problem
I'm no expert here Mike, but it sounds like your Dremel locked up.
This is how my Dremel acted when it gave up. According to the owners manual you are supposed to oil the bearings in it every 50 hours of use.
You will have to lay the saw on its side and remove the bearing caps and put a few drops of machine oil in the ports and let it set for about 12 hours and then flip it over and preform the same thing on the other side. Then cross your fingers that when you plug it in it will take off. Sadly this didn't work for me, but I did get a new DeWalt!
Good luck!
Here is the thread I started when mine acted up.http://www.scrollsawer.com/forum/showthread.php?t=6649Bill
DeWalt 788
aut viam inveniam aut faciam
Actually Bill, I have been doing this every other month. However, it is working again. It has been about 2 months since I have oiled it so I will do it again tonite and tomorrow. Also, it's still under warranty. I just hope I don't have to provide proof of purchase if I send it in. Don't have one.
Thanks
by Quartz43My wife and I got vaccinated this morning. I had worried that there would be long lines. But, the state of Indiana seems to have gotten it right. We went online 10 days ago and scheduled an bbc.co appointment. We got there as nd no line and went thru the check in, got our shots, waited 15 minutes...
Today, 12:08 PM -
Reply to More toysby theframerLooking great Jim. Can't imagine and little guy I know who would not want these. I may BORROW
your idea for my three nephews.
Thanks for sharing.
Rick-
Today, 11:58 AM -
Reply to More toysby Sandy OaksThose are way cute, Jim.
Today, 11:53 AM -
by Jim FinnThis is what I have been working on this week. Using lathe and scroll saw. about 7" long tanker. I have made 20 of each so far
Today, 11:03 AM -
by RolfThat's weird, on my Volume disk 5, in the index I have Aticle index, Issue PDF's, and pattern pullouts.
The pattern pullouts are broken up into 8-1/2 x 11 s
At he end of each issue is a copy of the entire pullout for that issue....-
Today, 09:39 AM -
