The new saw arrived today and I just had to get it set up eventhough I should have been sleeping (graveyard shift stinks). First the wingnut screws for the blade clamp were missing, but not a big deal, went to the hardware store and picked up some M6x1.0 cap screws and ground the ends flat. I'll make some knurled screws tonight at work. My problem lies in the table and blade position. There is not enough adjustment in the table so that the blade will clear the right edge of the hole. The blade when tensioned should in the center of the hole if I'm correct. Even with everything ajusted as far as it will go I am almost still on the edge of the hole on the right side. I took the table off for the 4th time and put the blade in and looked at my lines and things don't match up. Looking straight on at the blade it doesn't match up with the seams down the center of the saw, it looks like it's about a 1/4" off to the right.
Ok so how do I fix this or is it possible to fit it. I haven't called Dewalt yet and I'm sure they're just going to tell me to take it to some place farther than I want to drive. I don't know if it is possilbe to reassemble the arms so that things will line up.
Any help would be greatly appreciated because the wife is ready to cut and a farmer fix isn't going to be the best option.
Carl
Carl
