I am having trouble keeping the blade tight because the bottom holder is letting the blade slip. I have replaced both the wing nut and the torx screw on the other side. The saw has been good but is well used. The new Dewalt are made overseas, Has anyone had good performance with them? Has anyone used the Excalibur (EX21) long enough to know if it stands up to lots of cutting? Thank you>
Dewalt 788
Tags: None
I don't know beans about a dewalt I have a Craftsman but I have had the same problem and I can tell you how I fixed it , then maybe you can fix yours and keep on using the saw. There is a screw on the left side of holder for inserting the blade that you tighted right ? right. well there is also a screw on the right side that is for making the blade sit in the center of the holder. Right? right. Okay check both the screws and see of there is a bur on one or both of them.. A little sanding will fix that problem you are having. Sometimes the burrs are just a hair high so it won't hurt to do them both- better safe than sorry. you can also make sure that the right set screw isn't protruding out to much causing the blade not to get a sure hold. the set screw should be flat against the holder wall.
This has fixed many a saw that some had a lot of trouble with and this is how I fixed mine and many others said it fixed theirs too.
Hope it helps
Sharon -
In addition to trying some of the things suggested for your blade slipping out of the bottom clamp, try wiping the top and bottom of your scroll saw blade with a tissue. If there is oil on a new blade, you will see it on the tissue. I use Flying Dutchman blades and you will see the oil on the tissue from these blades. Most manufacturers of scroll saw blades put oil on them to keep them from rusting. Also you may have some oil on your blade clamps, can't hurt to check.................
Gary DW788 & Hawk G4Comment
I keep a scrap of 220-grit sandpaper next to my saw and run it on the ends of the blades; I paint the top end of the blades when I open a dozen, so I don't have to fumble around figuring out what way is up or down. The first few I put in were slipping out until I realized that the paint was flaking off. After I removed the residue from the clamping screw, I started sanding the ends a little bit to make sure it was bare metal.
BobComment
That's a good idea to paint the tops of all of your blades when you open a new dozen. I would only have to look at each blade once, with my glasses off. Another suggestion is to paint the top 5 or 6 teeth of each blade as it won't interfere with the blade clamps and those top teeth never get used anyway.................Comment
Do LED Strip Lights Consume a Significant Amount of Electricity?
Modern advancements in technology have opened up a plethora of energy options for people around the world. With a wide range of electrical devices available, individuals are faced with the task of choosing...-
Channel: Welcome Members
Yesterday, 10:12 PM -
Reply to Mitre saw material clampsby RJwebBetty, thx for the info will check it out, enjoy your day, RJ
Yesterday, 12:34 PM -
by RolfOur Judges are some of the best woodworkers I have ever met. On occasion I get asked to explain what I look for in the scrolling categories. I point out all of the nuances. I can't be a judge as I have intarsia and scroll work entries.
Yesterday, 07:36 AM -
by RolfThere may have been some crud on the tips from manufacturing.
In the ~20 years of scrolling I never cleaned the ends of my blades until recently. Even with the Pegas clamps I was having some blade slippage, I now scuff the ends of my blades with some 220 grit paper End of problem.!...-
Yesterday, 07:29 AM -
by NC ScrollerDon’t over sand them as you will shorten their usable life. Only sand as needed. Another thing to do is clear your blades before installing. Blades are coated with oil to prevent rust. Wipe the ends with alcohol or lightly sand with 320 grit.
Yesterday, 05:29 AM -
