I just purchased a sanding mop that is appropriate to use on a grinder or drill press. I assume since most grinders spin at 3000 rpm + that I should set the drill press speed up high also.
One piece of advise I can offer up. KEEP THE PIECE MOVING!!!!!!!! If you hesitate, you will get gouges in the wood. This is from experience. I run it at full speed on my drill press (about 3000 RPM) without problems.
I can't remember where I read it, but I seem to recall that mine should be 2350 max. In any event, hang on. Even so, you will probably launch a few things across your workshop if you get the end into the mop.
This is a Quote from the Stockroom supply Web site for their recommended speeds.
"One thing to remember about the mop is that speed is the key. The faster you spin the mop, the longer they will last and the better they will work. 6" mops need to be spun between 2000 and 3500 RPM's. 4" mops need to be run between 4000 and 10000 RPM's. Cordless drills and some electric drills do not have the required RPM's to achieve optimum results. "
Finish product : what would you use for the finish product , as on cherry or ebony? I like usually oil product but I did some tests with gloss varnish and It is quite good , because all the yellow and black base is quite glossy.
I have lot of fun to create the shade , by doing a lot of...
