Went to turn on my hitachi the other day and nothing happened.After trying everything i could think of i checked the motor by straight wiring it.It worked so it seems i have a bad circuit board which costs over half what my saw cost.Not sure yet what i'm going to do.
My saw is dead
Originally posted by mtnman4jesus View PostWent to turn on my hitachi the other day and nothing happened.After trying everything i could think of i checked the motor by straight wiring it.It worked so it seems i have a bad circuit board which costs over half what my saw cost.Not sure yet what i'm going to do.
Hitachi CW40 Parts List and Diagram : eReplacementParts.com
Try the switch thing first before giving up. I think you will be surprised.
John Wayne
D.W. is absolutely right. I eliminated the on/off switch, and use a foot pedal from Harbor Freight. There is also a foot switch on Amazon.com for a few bucks more. I have been using HF pedal for about 4 years of almost daily use.
Paul
I also had the same problem with my Hitachi, I put new switches in and it would work for a while then same problem. I eventually went and put one of the old switches in and press prongs and connector hickeys towards each other and the switch would work again. It became a pain for me and I don't know anything really about wiring so I just found a way better saw and put the Hitachi in the corner as a "just in case" Good luck.
Reply to Looking for compound cut ornamentsby Sandy OaksSo sorry for your loss. Sue Mey also added new compound cut ornaments that I thought were unusual. Here is a link: Compound cut ornaments #19 (scrollsawartist.com)
Today, 10:15 AM -
Reply to Wood lampshadeby planeurFinish product : what would you use for the finish product , as on cherry or ebony? I like usually oil product but I did some tests with gloss varnish and It is quite good , because all the yellow and black base is quite glossy.
I have lot of fun to create the shade , by doing a lot of...-
Today, 09:14 AM -
Reply to Looking for compound cut ornamentsby meflickThanks for adding the Ornament Book Don, I had forgotten it has some compound patterns in it,...
Yesterday, 11:31 PM -
Reply to Alex Fox Basket C16by Sandy OaksThanks for the nice comment. Actually, not very fragile....Yesterday, 10:57 AM
Reply to Cutting is doneby planeurWOW ! So much work and patience ! Bravo, beautiful !
And the fine cutting is something . I have a lot of patience but that much....!🙄
planeur-
Channel: Works in Process
03-19-2023, 09:32 AM -
