I know not many people use the Ryobi scroll saw but hopefully someone has an idea. I've been using this saw faithfully for a year and have no problems except for the tension rod, which I have replaced. The other day the tension rod was getting hard to tighten so I cleaned it with WD40. Put it back together and now, I tighten the blade up, which tightens very easy now, but when I turn the saw on to use it I watch the tension nob loosen. It turns and loosens very fast. I took the rod back out and cleaned with dish soap to get the oil off and it still does it. It will not stay tight, it loosens as soon as I start my saw and at any speed. Anyone have any ideas? All help is appreciated. Don
Ryobi SC164VS scroll saw.
i have 2 of the ryobis i use, ive replaced the rods twice in each one, the first one stripped ,thye second one had burrs in the threads and a small crack , it was doing the same thing as yours i just got fed up and bought new tensioning rods they both work fine now
Did you check the tensioner knob at the rear of the saw....? if the "INTERNAL " threads are worn it can cause the same problem.....then, IF you have a wornthreaded shaft it can compound the problem.......replaceing one without replaceing the other will TEMPORARILY cure the problem.....replaceing BOTH at the same time will result in longer lasting satisfaction.....neither are very expensive.
my saw is about 5-6 yrs. old and still holds the adjustment well.....most of my work is "FRET" so the handle is used quite a bit.........also the rubber collar at the top of the shaft just under the black knob helps to hold it in position.....kind of a lite friction. be sure it has NOT been removed or hardened. It also acts as a cushion
Thanks so much for your replies. The threads LOOK ok, and it worked well till I cleaned it. I"m probably going to just buy a couple, the shipping is the worst part, to have some spares. I just hate having to wait the 7 to 10 days to do any scrolling. I have a 24" 2 speed craftsman, but the 2 speeds are just not what i need. The low is too low and the high is TOO high. Guess I'll just make do. Again, thanks for your replies. DonDon
Don
Glad it worked for you. Maybe if you put the Teflon on the new pieces right away they might last a little longer. Most threads are kind of sloppy to begin with, if you take any screw and a nut and try rocking the nut perpendicular to the screw you will see what I mean. This is usually not a problem when you are using screws to clamp things together but with the tension rod being pulled tight and then loosened every time you change blades or holes I can see where it could cause problems.Tim
In God we trust, all others must pay cash!
I don't want no bargains, they always cost me more money.
Reply to YoraHome Laser w/CNC Engraver/RouterNew toys sometimes become tools we can use, and other times they simply are tools toward expanding our horizons and being there when an idea pops into our heads. Let us know what you try the Ortur on and how it does. I'm sincerely curious. Also....why did you choose Amazon vs the other vendors...
Yesterday, 11:47 PM -
Reply to First you need to make a messby will8989It was a challenge that’s for sure. I didn’t start anything until I was all finished. It’s nice to have a clean area to work in! My biggest challenge was all those pieces of scrap wood that I just might need “someday.” They burned well in my son’s woodstove. And I did get through all the patterns....
Yesterday, 10:54 PM -
Reply to First you need to make a messby tgiro01Wow - Betty, what do you charge. I have things to do and I'm in the process of cleaning my shop, just to have room to do it. My problem is that I get the work bench cleared and then start working on projects again. I really need to do the workbench last.
Yesterday, 10:05 PM -
Reply to YoraHome Laser w/CNC Engraver/Routerby tgiro01I ordered and received the ORTUR Laser Master 2 from Amazon, the but haven't had a chance to even get it out of the box. Too much going
on right now. I got the 20 watt version, which is supposed to be good for cutting, but I don't think I'll be doing much of that. There will be a learning curve...-
Yesterday, 09:57 PM -
