Saw Broke
  • Saw Broke
    Go figure...I am trying to get a memorial cutting done x4 and the pin that holds the upper blade holder in place breaks, that in it's self is not the bad thing as it would have been an easy fix. But guess what? Sears does not carry that specific pin as it came with the replacement holder and they no longer carry the replacement holder. If I can not find a suitably sized pin to repair my say I will be out of a couple hundred dollars of commission............^%##^&*&#*(*(#%^
    CHRIS
    http://www.members.cox.net/messman123/messman.htm
    That is messed up. Can't make a pin out of some scrap metal?
      Not sure of what you need but Lowes or Home depote have an assortment of roll pins.
      If not there go to McMaster-Carr
      You should be able to find a suitable pin there with very fast delivery.
        Chris try going to ereplacementparts.com They carry a WIDE array of parts for a lot of different saws
        DW
        John Wayne
          Thanks for the info guys. Rolf it was a solid pin not a roll type.
          What I ended up doing was to call my good friend Micky Mouse while at Lowes, and we decided to give a hinge clip pin a try because I could not find anything except that, which came close to the proper diameter. So after spending 76 cents and about 3 dollars in gas I made it home and cut the pin up some, put it into the hole and bent the ends of it a little so it would not slide out. Now I am back to cutting. Then I called Micky back and thanked him for the idea...Man you gotta love the Micky Mouse ideas you come up with to fix things, so the work as good as new......YEAAAAAAaaaaa
          CHRIS
            Drill Bit shanks make great pins and they come in decimal sizes so there is a big range of sizes.
              Glade GREAT suggestion never thought of that as an emergency resource. I fortunately have a small metal lathe in my basement so I can make whatever I need.
