scheppach deco flex problem
  • scheppach deco flex problem
    have had this saw for awhile with no problems,, today i turned i went to use it ,and it has a bad tapping noise coming from inside the casing near the tension adjuster,and when i saw it seems to labour and sounds strange and vibrates like made, any ideas on what has happened,,,, it is oiled regularly,
    thanks
    Maybe the counter weight came loose on the motor shaft. That happened to me on my old delta. All of the set screws were loose and threw the whole saw out of balance.
    Locktite and lithium grease on all the joints and it still runs like a charme.
      thanks Rolf checked that, seems to be in the tension adjuster area,in side the casing,
        fixed was tension spring,,, whew,
        • Sandy Oaks
          Teach - Learn
          by Sandy Oaks
          This gallery has 2 photos.
          Today, 12:13 PM
        • Sandy Oaks
          by Sandy Oaks
          Today, 11:22 AM
          Today, 09:54 AM
          Today, 09:51 AM
          Today, 09:42 AM
