I've been scrolling for several months, learning new things from the forum and from trial and error. I've seen some posts on blade tensioning but wanted to get some advice on blade speed. Is there a recommended speed at which to run the scroll saw ? Also, does it vary when using hardwoods compared to pine or Baltic Birch and/or the thickness of the material being scrolled ? Any advice will be appreciated !
Blade Speed Question
Re: Blade Speed Question
There are a ton of variables involved. The speed you use will vary from saw to saw, wood to wood, your skill level, agressiveness of the blade, even blade to blade within a batch, etc. The only real constant is start slow and as your skill level increases so will your blade speed. You'll eventually get a feel for what speed suites you on an individual project. Probably haven't told you anything you alread haven't figured out for yourself.
OK..I have a question for you...I am working on an idea for a carving, the bandsaw isn't really practical for this particular shape and the scrollsaw would be ideal, but the wood (basswood) is about 2 inches thick! I have done some scrolling on thin stock 1/8 1/4 and even some 1/2 but not that thick....what blade speed is good...I am assuming high speed....also what blade? thanks Dave
Dave I don't know if this will be a help or not...just an observation on scrolling I've done with my old Boise Crane jigsaw. Â This is similar to a scroll saw but is a lot bigger. Â Originally it had a very slow blade speed and it vibrated something fierce. Â I changed the driven pulley down to a 1' one and the speed and vibration improved dramatically. Also helped a LOT with blade breakage. Â Next time I get down to the hardware, I'll pick up one or two bigger drive pulleys and see what that does. Â With this old giant of a saw, I can handle up to 4' thick material and up to a 1/2' wide blade. It's just an old dinosaur but I really hate to get rid of it!
Anyway, so far, the faster my blade speed, the better and easier the cuts. Â I suppose there must be a point of diminishing returns, but it looks like I have a long wway to go before I reach that point. Â Probably should get the pulley size and stroke ratio and figure out exactly what the drive RPM and SPM rates are. Later.......
As far as blades go I've been using standard coping saw blades (knock out the pins) and salvaged broken bandsaw blades. Easy to come by and puts the busted ones to good use!
Al
If I don't have a lot of detail to cut in the roughouts, I use a 1/4', 6 tpi lenght of bandsaw blade. This is too heavy a blade to do a whole lot of sharp turns, though, but if you can back up and take another swipe, it cuts fast and is almost impossible to break. For anything that requires any turns of consequense I use a standard 10 tpi coping saw blade.If your scrollsaw can adapt to either one of these, give them a try. cheap and easy to find.
For most work, even with the smaller blades, I run the tensioning spring out to almost 3/4 length. That's probably 20 to 30 pounds of tension. I know that is a lot more than most scroll saws are capable of, but that's what I use. Like I said, this saw is a beast, but I don't want to get rid of it. I inherited it from my dad about a million years ago!
Al
I think we are still talking scrollsaw so to answer that If your scrollsaw can handle 2' cutting depth not all saws can, you want to use a fast speed a #12 blade, lots of tension, and most important let the saw cut the wood and try not to push sideways. If you put too much sideward preasure you will not get a straight up and down cut it will have a bevel to it. Good Luck!John T.
Actually, in an upcoming issue of SSW, we address that a little bit. One of our pros said to put your hand flat on the table of the SS and (with the saw off) press your thumb against the blade. It shoudl give about 1/8 inch.
The article will be under the Tips and Tricks section (I don't have it in front of me right now, and I can't remember what else the pro said.)
by RolfI periodically get asked if I am still making the kits. The answer is yes.
I get a private message on the forum to which I reply but suspect new people to the forum don't check for a response.
So please, if you have sent me a PM check for a response.-
Channel: Author Questions
Today, 07:50 AM -
Firefighter - my latest
Firefighter pattern
...Yesterday, 08:27 AM -
Reply to Hegnerby RolfThe Hegner like some other saws have a sweet spot or not so sweet spot where they may vibrate. I know they need to have a solid footing.
When we were younger (2005) we used to bring our saws to our club meeting in an old barn with wooden floors. The seasoned scrollers all had Hegners. The rest...-
Yesterday, 07:46 AM -
Reply to Eccentric adjustmentby RolfI assume you are talking about changing the stroke length. Looking at the manual it says you can shorten it for cutting thin wood and or metal. I have never known anyone that did that. We have several Hegner owners in our club. I am not one of them.
Channel: Beginners Scroll Saw
Yesterday, 07:37 AM -
