blade question…..
yeah dg, i do love the UR’s most….i tried the 5 dif kinds from the sampler pack, and couldn’t tell if the polars or the penquins cut any better than the UR’s, so that’s what i went right back to…i’m thinking that the more UR’s, the merrier…lol
I prefer the #5 & #7 UR for my compound cutting depending on what wood I'm cutting but the polar do a good job as well. So personal preference..send the other Mike a message and ask him to explain the difference between the other ones you mentioned.."Still Montana Mike"
Rivaz we can get the Pegas blades here in North America. I recently purchased some to try. I find that in softer woods (Walnut, Beech etc) they work very well and I can't really tell much difference from the Flying Dutchman. But with very hard woods like Purpleheart there is a huge difference the FD's cut faster and last much longer before dulling. To date the Flying Durchman are the best I've tryed
Hi Stan, I found out that Pegas blades are available by several retailers in North America like Ben Fink or D&D woodcrafts. I've also heard that Woocraft started to sell it.
I just worked today in purpleheart and I was realy confortable with the Pegas Modified Geometry.
Hi Tim,
I believe you sent me an email but will explain it here also.
Both the UR and the TC have two down and one up. However the tooth design is completly different. The UR cuts a lot more straight because the blades are milled different.
Also, I believe the UR is the first on the market telling you what is the top of the blade. Customers really like this. The blades have a tinny marking on one end, telling that it is the top.
Diana Thompson likes to use the FD-Polar for compound cutting. She uses most of the # 5 but also some of the # 7.
You do not need a blade with reverse teeth. The pieces what have the fuzz, you throw away anyway. The teeth are off-set just a little, this helps to clean the kerf in thick wood.
FD MikeLast edited by 3_M; 05-11-2012, 05:01 PM.SD Mike
Reply to What do you think?by Gary beasleyI tried a house vac once for a dust collector. It was prone to clogging the lines and when I tried to put a cyclone can on it the vacuum collapsed the garbage can.
Yesterday, 09:29 PM -
Reply to Vasesby Gary beasleyI found this pattern in Steves catalog and freehanded a vase form. This one may appeal to the folks that bought the butterfly vase.
...Yesterday, 09:25 PM -
Reply to My lucky day!by Bill WilsonBeing younger than 65, with no qualifying health conditions, I don't anticipate getting a vaccine for some time. My wife works for the school district, so she may be eligible in the next phase. President Biden says that supply will be sufficient for all US adults by end of May. I'm hoping that proves...
Yesterday, 04:16 PM -
Reply to What do you think?by MidMich324Will a shop vac work for the table saw?.
Yesterday, 11:26 AM -
