I've been looking at buying the dremel flex shaft Dremel flex shaft but I wondered if I needed anything else? In the listing on Amazon they show buying it with the multipro keyless chuck. Is this something I would need in order to use it??? I could see this as a real help with sanding small hard to reach spots. Any thoughts on this??? Thanks so much!!!
Dremel flex shaft
Cathy, I am not familiar with the Dremel flex shaft, but, I have a Dremel "Stylus" rotary tool. It is a pistol grip rotary tool with variable speeds. That's what I use for small sanding or grinding. I do have a flex shaft on my Roto-zip, rotary tool, but, that is very high speed, and it has a wrench to tighten each bit that is used. You would not want to use it on very small items. I'm sure someone has one & will give you some good advice on that item. Good LuckPERK
I also have the Dremel 400 hanging from the rafters with a flex shaft and keyless chuck.
I have mine connected to a foot switch to keep my hands free. The keyless chucks eliminates the collets when you go to different shank size bits.
I call it my poorboy Fordham.Rolf
I'm always amazed at how many use the Dremel tool and flex shaft. I've never been able to wrestle the durned thing into submission. Both are collecting dust. I guess I'll have to do more practicing with them. I've sure created a pile of designer firewood trying.
Jan
Cathy, I have a flex shaft rotary tool, but it's not the dremel. Mine is a Weecher (sp?). I got this one because it's thinner than most and I can hold it like a pencil with my stubby fingers. The other cool thing was it has a carving attachment - kind of like a mini jack hammer. I love having the flex shaft - much more control.Janette
www.square-designs.com
Mark
I may be wrong but I do not think the flex shaft would work on the Multimax, the reason I say this is because the flex shaft is for a rotary tool (spinning) and the Multimax is an oscillating tool.Tim
In God we trust, all others must pay cash!
I don't want no bargains, they always cost me more money.
I use my Dremel and flex shaft daily. One thing I recommend is keeping lubed.
I use "Speed Grease" a water resistant grease for the flexible prop shafts on my RC boats. Any quality non graphite would do. Take the shaft out of the housing, put a gob in the palm of your hand and pull the shaft through it while spinning and flexing a few times and wipe off all excess grease. It does flex but keep it as straight as possible while using it. I'll ease the motor drag and extend the life. Don't over do you don't want it leaking through the housingMay the wind at you back .....
Not be from Lunch.
Oily's Gallery
Originally posted by evilbadger View PostMark
I may be wrong but I do not think the flex shaft would work on the Multimax, the reason I say this is because the flex shaft is for a rotary tool (spinning) and the Multimax is an oscillating tool.May the wind at you back .....
Not be from Lunch.
Oily's Gallery
by Quartz43My wife and I got vaccinated this morning. I had worried that there would be long lines. But, the state of Indiana seems to have gotten it right. We went online 10 days ago and scheduled an bbc.co appointment. We got there as nd no line and went thru the check in, got our shots, waited 15 minutes...
Today, 12:08 PM -
Reply to More toysby theframerLooking great Jim. Can't imagine and little guy I know who would not want these. I may BORROW
your idea for my three nephews.
Thanks for sharing.
Rick-
Today, 11:58 AM -
Reply to More toysby Sandy OaksThose are way cute, Jim.
Today, 11:53 AM -
by Jim FinnThis is what I have been working on this week. Using lathe and scroll saw. about 7" long tanker. I have made 20 of each so far
Today, 11:03 AM -
by RolfThat's weird, on my Volume disk 5, in the index I have Aticle index, Issue PDF's, and pattern pullouts.
The pattern pullouts are broken up into 8-1/2 x 11 s
At he end of each issue is a copy of the entire pullout for that issue....-
Today, 09:39 AM -
