Hello everyone
I was wondering if anyone had an issue with the blade holder on the Excalibur EX-21. There is an allen screw (#37 in the attached part disgram) opposite to the butterfly used to tighten the blade that keeps getting loose. The result is that this screw eventually turns inside the holder resulting in a bending of the blade and a misalignment when you tighten the butterfly. The fix is quite easy as you simply need to tighten that screw against the butterfly again.
But it does not make sense that you cannnot lock this screw in a permanent position and avoid the loosening up.
Am I missing something? Does anybody else have this problem?
Alain
Alain
