When it comes to electrical issues my sum knowledge of the subject can be written on a piece of toilet paper and then flushed for what good it is! Please - I need help from any electricians in our member base.
I have a Dewalt saw I bought in Italy several months back. Its a Type 1 Model DW-788-QS fitted with a 230v 50 Hz 0.4amp 75 watt motor running 450- 1750 spm (thats not a typo for rpm - it does say spm!)
I want to run it back home in Mexico which is the same 110 v power supply as in the US and Canada
An electrician at the factory here in Italy told me I could probably run it from a step up converter but he wasn't 100% sure. I found a link to a supplier of what seem to be suitable converters but would like someone in the know to to tell me if these are what I need. The page link is
Region Free DVD Players, PAL/NTSC LCD TV, 110/220 Volt Appliances & Electronics
As I also have a 220 volt Dremel which I'd like to save which is rated at 125 watt I'm thinking that a 300 watt converter would serve my needs with some power in hand but am a little confused here that the saw motor is rated a lot lower than the Dremel.
Can someone please confirm if what I'm looking at will work, what size will I need and will I have any problems with the speed controller board on the saw or do I need to change that.
Note - I've looked at buying a new motor from the USA but at 205 USD plus 120 USD shipping to Mexico plus the possibility of being hit with 30% import duties I'm trying to find a more economical solution.
Failing this I'll remove the darn motor, convert it to a tooth pulley drive mechanism and run the saw indirectly by belt from a locally bought variable speed industrial sewing machine motor.
Am I kidding? Not me - LOL!
Thanks in advance for any help
