I just cut my first puzzle with the Flying Dutchman Superior Puzzle blades from Mike. I think I used more blades than would be considered normal. For those of you using these blades how many blades would you have used to cut a puzzle similar?
Here is some info about the puzzle.
The wood is Poplar - 0.25" x 5.5" x 5.5" and had some cupping.
The saw is a Hegner Multicut - 2
The damage 16 FD-SP blades.
At first most blade breaks were happening at the clamps and then more started happening in the middle. I've only recently started using this Hegner so I don't have much experience on it. Previously I cut two similar shaped puzzles with a FD-SR5 and still had blade life left. I would expect a longer blade life with the SR5 as it is wider (.0015 to .0008) has bigger teeth adn more spacing than the FD-SP.
I'm just wondering how normal/abnormal this life is.
Thanks.
Thanks.
