I do a lot of fret work. My patterns are printed on 20# bond, mounted to my
wood with spray adhesive and then covered with clear packing tape.
My problem occurs only when using spiral blades. The fibre from the paper
is pulled up thru the cut, effectively "blocking" my line of sight.
Since the fibre is not loose, the blower is not effective.
Would appreciate any suggestions & advice.
