using speed square
  • using speed square
    I must be getting old. I have forgotten hoow to use a spped square.I am making a gun cabinet.I need to cut a piece of 1/2 oak plywood. It is 8 inches wide and 13 1/2 long. I need to keep the 131/2 on the bottom side with the30 degree.ending on the corner. I have spun the square a dozen different ways until i almost ready to start a bon fire. I still havn't got it to work. I have done this before I'm just having a little trouble remembering how.
    Kevin
    When you hit rock bottom the only answer is to look up
    Kevin:
    I am sure you know a speed square is for rough framing lumber, and not for fine woodworking.
    But anyway:
    Since I published the first review of the Swanson Speed Square, many people have been wondering how to use it. There are actually a large number of things you can do with it, but the most common is probably to
    a rise of 7 inches over a 12 inch span is really 30.26 degrees. While 6 15/16 inch rise over 12 inch span is 30.03 degrees.
    Phil
    • alexscrollsaw
      Firefighter
      by alexscrollsaw
      Firefighter - my latest
      Firefighter pattern
      Yesterday, 08:27 AM
      Reply to Hegner
      The Hegner like some other saws have a sweet spot or not so sweet spot where they may vibrate. I know they need to have a solid footing.
      When we were younger (2005) we used to bring our saws to our club meeting in an old barn with wooden floors. The seasoned scrollers all had Hegners. The rest...
      Yesterday, 07:46 AM
      Reply to Eccentric adjustment
      I assume you are talking about changing the stroke length. Looking at the manual it says you can shorten it for cutting thin wood and or metal. I have never known anyone that did that. We have several Hegner owners in our club. I am not one of them.
      Yesterday, 07:37 AM
    • Dave56
      by Dave56
      Has anyone made any adjustments to the eccentric or connectors on the Hegner M22
      03-30-2023, 04:59 PM
    • Dave56
      Reply to Hegner
      by Dave56
      Has anyone replaced the eccentric on the Hegner scroll saw or made any adjustments to this part.
      I bought an used Hegner m22 and it vibrates at about 3/4 speed. Maybe I'm just over thinking this problem, last year I purchased a multi cut 3/25 inch Hegner it is a single speed and it runs like a...
      03-30-2023, 04:50 PM
