I am new to scrolling (actually bought my saw a couple of years ago but because of problems just now getting to explore scroll sawing). I found when I started to use my saw I found that, first the lower blade clamp bolt was missing. I called the factory and they sent a clamp bolt. When I went to install the clamp bolt, I found that the bolt will not screw in enough to tighten or even touch the blade. I called Hitachi and they said to box up the saw and send it to Georgia. I tried to get them to send me a new lower blade holder clamp, but they asked me to call an authorized service center. I tried this and after 4 phone calls a finally talking to a tech. The tech agreed I could CAREFULLY tap out the blade holder which should allow the clamp bolt to go all the way through to tighten the blade. Other than this, I really like my saw and it works great with pin end blades. I haven't broken a blade yet after a couple of dozen projects. Anybody else have this problem?
blade clamp problem with Hitachi CW 40
sounds like you might have had a one of a kind manufacturing defect in the clamp itself......i started out with a cw40, but after experiencing a bunch of small problems on 3 replacement saws from Lowes (bad motor, loose bushings in the upper arm, along with my inability to feed from the bottom i took it back and traded for another cheapy at Home Depot.(Ryobi) after 3-4 years its still going strong.
Reply to Picked up a new toy yesterday!by jim_mexHi Rolf - I bought the Marietta through Amazon Mexico. I never thought to check if it showed on the US site. I use both of these sites quite a lot but where possible buy through the Mexico site even if items are listed as being imported because import duties and delivery charges where applicable are...
Yesterday, 06:22 PM -
Reply to Sanding and calibration disk.Thank you for sharing. I'd seen that item but didn't get it. Now I'm glad. Will wait and see how they respond to you....
Yesterday, 05:42 PM -
Reply to First Project - Stretching CatThat turned out very nicely. And that paint really set it off!...
Yesterday, 05:40 PM -
Reply to First Project - Stretching Catby NC ScrollerNice job. Scroll sawing can be addictive.
Yesterday, 04:41 PM -
This my first project from the Scroll Saw Workbook. I used a veiner gouge and some acrylic paint to finish it....-
Yesterday, 04:27 PM -
