Picture of saw fix for ROLF
  • Picture of saw fix for ROLF
    Hi
    Here is a picture of the retrofit I did for my blade holder. It is a 1996 18vs.
    I used a steel angle bracket to move the blower to other side.
    Bill
    DEWALT 788 and Hegner 18vs..... AND STILL CUTTIN IT UP!!!!
    Member of Scrollsaw Association of the World
    Thanks that is a neat solution.
      Thanks for posting the picture of your set up Bill
      Hawaiilad
      Larry
      • tgiro01
        Old Tool - Reborn
        by tgiro01
        With all these new tool stories, I was working on and old one. About 9 years ago, I built a router table. Then, before it was finished, I had to start using it. And I have used it over the years. A couple of months ago, While I was contemplating cleaning, I looked at the machine and decided to finish...
        Today, 03:24 PM
        I do remember that 2011 Wow, you were gutsy building that then, CNC was just coming into the home environment. Are you still using the one you built?
        Today, 10:23 AM
        Jim that is why there are now CD's available for past issues. To me a copier/scanner and printer are a necessary part of my tool inventory. JMO...
        Today, 10:19 AM
      • Jimern
        by Jimern
        I dropped my subscription long ago, so maybe I should not chime in, but I dropped it mostly due to the pattern pull out.
        But the result is that if I cut a pattern to scan, I have also cut the parts of...
        Today, 07:55 AM
      • Quartz43
        by Quartz43
        +1 on NC Scroller's suggestions. I would add that on appropriate patterns stop using the grey as it would make it easier to copy.
        It says a lot if Fox Publishing does not comment on an issue like this. Even if they said they are aware that people have concerns and are looking into it...
        Yesterday, 08:15 PM
