Dust removal @ the blade
Stephen, I don't know if you saw my posts on the dust collector I use but maybe you can use them.
http://www.scrollsawer.com/forum/gen...-saw/31024.htm
http://www.scrollsawer.com/forum/gen...-saw/31025.htm
Any questions feel free to ask.Chuck D
Jean De La Bruyere...
l
Stephen my set up at the blade is hooked to a shop dust collector, not a vac. No reason a vac wouldn't work with the right attachments. It's about 20 feet away from the saw, I use to have a chain holding up the hose, but I bought this flex hose and I like it better. I have it hooked to a hook on the ceiling, then connected to the tube going to the collector. The other smaller hose you see is for the bottom of my saw. Any set up is better than nothing. I like that flex hose because I can adjust, and twist it any which way to accommodate the thickness of my project.
As an aside.......my mom use to say "Cripes" all the time, just like you.
flex hook up (Small).jpg flex hose (Small).jpgGloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Thanks both of you. Really neat the way it is hung from the ceiling. I could do that I think.Pacifism is great, as long as everyone is participating.
StephenD
Desert Woodcrafters
From a 2012 post I found using this web site's search engine, maybe this is what you are looking for...
https://www.scrollsawvillage.com/for...using-gimp-l1/...-
Today, 12:18 PM -
by shop dogHi everyone...long time, no post.
Last year, i was using a website to generate scrollsaw portraits. I lost the link, and forget the name of the site. If it's permitted here, could someone refresh my memory?
Thanks, Steve-
Today, 11:54 AM -
by RolfPT, as painful as it can be is crucial! I shattered my right elbow in 2003, 5hrs of surgery and lots of hardware put it back together.
The PT brought tears to my eyes many times But I now have a full range of motion. The only thing I can't do is throw stuff like rocks and frisbees my elbow lets...-
Today, 10:37 AM -
Reply to The St-Nicolas sheriffby jim_mexHi Planeur - this sure is an amusing character and I fully understand why you like it. Also, since it is your first intarsia piece you should definitely keep it and sign and date the reverse. It will serve as a great benchmark for your future projects to see how you progress.
Some...-
Today, 09:34 AM -
