3-Leg Stand for Delta SS350
  • 3-Leg Stand for Delta SS350
    I was wondering if anyone happens to know if the stand for the Dewalt DW788 can be adapted to fit a Delta SS350?
    Have you Googled it , I google everything that I'm trying to find an answer too.......I would think that it would - but then it's a guess on my part too..............MB
      KJS, I doubt that the holes would line up the same. You could always bolt a piece of plywood to the stand then drill new holes for the Delta. Good luck with it.
      Mick, - Delta P-20
        I built my own with a 24 in by 24 in table and 3 legs. I used 4x4's for the legs and put the single leg at the front so that I could get my knees under the table for closer visibility. I sit in a swivel office chair. Works for me.
              Thanks Silver. I had thought about maybe building one myself, but figured after I added up the material costs plus the time spent running to the lumber yard and putting it all together, it would probably be less expensive for me to just buy the stand and bolt it together. I can order the Dewalt stand online for $69.00.
                So this is the final result using the Delta/Dewalt stand I bought from another member here for my SS350. I made some spacer blocks out of 3/4" plywood for the front and rear recessed areas and attached a 24" X 30" 3/4" plywood base with some carriage bolts. Nice and sturdy and doesn't take up too much space. The extra work surface area will come in handy as well. Time to start making some sawdust.
                    KJS, looks like a very nice setup. You could install a foot switch at knee height on that stand. I put one on my saw stand and just bump it with my knee to turn the saw on and off. There is no sawdust on the floor or the stand. Enjoy your new saw.
                    Mick, - Delta P-20
                      Thanks Mick. Good idea about the foot switch . I'm going to order one from McMaster-Carr this week.
                        That worked out well for both of us, Ken! The extra space is definitely an advantage. The cabinet I put my saw on has a large surface which gives me a place to put puzzle parts as I cut them. I'm planning to put a plywood lid on with holes for cups that I can keep blades in (the cabinet has a hole where the belt wen through for the old saw). Laying #2 blades on the surface looks like a recipe for losing them!
                        I also like the idea of a knee switch. While I was working I couldn't think of a good place for a foot pedal, but the knee one would be easy.
                        Anthony
                        "There's a very fine line between a groove and a rut."
                          • handibunny
                            Reply to Old & New
                            by handibunny
                            A gift to be cherished, and a reminder that life goes on despite a tragic loss. How lucky the little boy is to have such caring people in his life....
                            Today, 07:32 PM
                          • Misouri Wayne
                            Reply to Old & New
                            by Misouri Wayne
                            Very nice tribute. Thanks for sharing.
                            Today, 06:55 PM
                            Reply to Festool vac and Pegas scroll saw
                            Jo, when I got my hegner long ago it had a light with it. In the back of the light was an outlet for the footpedal. I put in a 3 prong plug and plugged in my footpedal and vacuum. Ran great for 15 years. A few years ago the outlet on the lamp died and my footpedal at the same time. I had to replace...
                            Today, 01:27 PM
                            Reply to Old & New
                            I got chills reading that. A treasure for a lifetime.
                            Today, 12:01 PM
                            Birthday presents for grandkids
                            Conversation with Bruce. I need some beads for the dream catchers. Bruce - let me go look through my stash. I have what you need. Me - of course you do. When I first started doing shows, Bruce would go and make dreamcatcher earrings and other jewelry. He was quite good at it. Of course he was. He kept...
                            Today, 11:59 AM
