Delta Blade Lock Won't Stay Locked
  • Delta Blade Lock Won't Stay Locked
    Hi everyone,
    I am new to scrolling and have a Delta 350. I bought the saw brand new almost 4 years ago but life hasn't allowed me to use it until now. I set up my saw and start seeing what it will do. The first couple of times I changed blades, the quick release blade locks stayed locked. Now, all of a sudden, they won't. Can anyone help me please?
    I removed your picture you will need to re-size it and then follow my instructions below.
    Kenn
    Delta 350
    I think you need to re-size your picture....
    Just a tip...
    Here is the preferred way to post photos. This method will apply a thumbnail so that messages load faster, keeping those who are still on dial up in mind.
    If it is a new thread scroll down below the message box to additional options and look for manage attachments,Click on Manage Attachments, click Browse, find your file name on your computer, click it, then click Upload. It may take a few seconds to load.
    Once you see the file name under current attachments you can close the window.
    If you want you can Preview Post (a wise choice) then if all is well, click on Submit reply.
    If you are uploading a picture to an existing thread (conversation)
    Click on the Go Advanced button under the reply box, Click on Manage Attachments, click Browse, find your file name on your computer, click it, then click Upload. It may take a few seconds to load.
    Good luck
      OK, Let's try this pic again. Thanks Wood.
      Kenn
      Delta 350
        There ya go...Good job.
          If it is anything like my Q3 and other Delta quick change blade holders, there is a small U-shaped spring which holds the two halves of the blade holder together when you close the lever. If it is missing, it just won't stay closed. Been there, done that.
          george
          George
          delta 650, hawk G426
            George is correct but also you might have to adjust the tension knob that tightens the clamp.
              It appears that from the picture that you might have to back off the knob on the right just a tiny bit until the left lever locks into position. I had this problem before and found this to help me.
                Kenn, I have a Delta with the quick change blade holders and had a similar problem. There was a small piece of a broken blade in it which wouldn't allow the blade to lock. I took the blasted thing apart to see what was going on. There are two springs in that thing: One is the U-shaped spring and another is a very, very, very tiny compression spring. Of course that's the one I lost. I had to get a replacement. So be careful if you take it apart.
                Dan H
                  Thanks everyone for all of the input. I seem to be experiencing everyone's previous issues all in one.
                  I had tinkered with the tension thinking maybe it was too loose or too tight. Then I started taking the clamps apart to see if something was jammed up and whoops, lost one of those springs. I got another spring from the hardware store, put it all back together but still no luck.
                  I'm thinking I may need to order 2 whole new clamp setups. Looks like I'll spend Thanksgiving eating more turkey and watching more football.
                  Thanks again for the help. At least I know I was looking at the problem the right way.
                  Kenn
                  Delta 350
                    Good luck Keen, I have one of those locks on my Delta too. That is the reason I use my Hegner a lot. And I have changed the clamps 4 times..
                    Chuck D
                    Jean De La Bruyere...
                    l
                      Hi Kenn -no problem at all with my QuickLock clamps - I have the model 2 version on my saw. Assuming you have all the parts in place it does take a bit of trial and error to initially get them to work right but usually adjusting the knurled semi circular tightening nut correctly solves the problem. Screw it too far in and you can't close the clamps without a heck of a lot of pressure and risk breaking the levers, ease it back too far and the clamp won't grip the blade. Also check that the clamping surfaces have no oil on them - A light pass over with a fine size wet and dry paper with help. Don't forget that if you change blade sizes you will probably need to adjust that nut again.
                        Jim - Thanks for the info. I'll see if that makes a difference.
                        Kenn
                        Delta 350
