They get dust in the switch.Take out the two screws that hold on the switch and blow it out.If that don't work wiggle the wires around a bit,works for me.
Mine did that. Spin the movement (take off the green cover to see it) and then hit the switch. May need to do it a few times. Just a gremlin acting up.
Thanks everyone for the suggestions,i try them all none work. Is the a way to bypass the on/off switch
to see if it still runs before i buy a foot switch
There are probably only two wires on the actual switch body. Pull them off and make a wire jumper to go between them and then plug in the saw. If it starts, then the switch was bad.
Unless you are comfortable around hot wires, I would suggest jumping the connection first--then plug it in!
check if you have good plug ( in the wall inlet ) couse with time it start to wear (from inside) lose leads , and it might be the switch too , you may bypass it or just make a short between the wires of the switch if it work, then you have bad switch if not then check , if there is a fuse inside the control board of the saw .
