GGRRRR! 788 problem
  • GGRRRR! 788 problem
    My DW788 will not keep holding the blade. As soon as I put any tension on, the blade pops, either off the top or bottom clamp.
    I tried cleaning the clamps thoroughly, tried to flatten the ends with a wet stone, but still jumps out.
    I just ordered some new set screws and clamp knob, so hope that helps.
    The knob cost over $8 each. Ridiculous!
    John
    Old Dust
    Hey John, It's a common problem with the DeWalt saw. What will help is to clean off the oil from the ends of the blade. I use a folded piece of 220 grit sandpaper to do this. I also sand the ends of the thumb screw. If the end is shinny, sand it till it is dull. Make sure you don't round it off.
    Dan in So.Ca.
      Maybe the parts will get you up and going ..........
        Make sure the end that holds the blade turns . There is an o ring that holds the end in the thumb screw.Might have some dust in it .
        Roger
          Today, 07:36 AM
          Today, 07:29 AM
        • NC Scroller
          by NC Scroller
          Today, 05:29 AM
          Yesterday, 08:46 PM
          Yesterday, 08:45 PM
