I have a Dewalt 788 20 in scroll saw. Having problems with the lower blade holder bending the blades and eventually breaking them. Only bends on the part of the blade that is inserted in the holder. Suggestions?
The side of the blade holder that doesn't have the thunbscrew, has a set screw. One reason for the blade to bend, within the blade holder, is that the set screw isn't screwed into the blade holder far enough. When you tighten the thumbscrew, you are pushing the blade against the empty hole of the set screw which bends the blade.
Screw the set screw in far enough so that the blade is centered in the slot of the blade holder when the thumbscrew is tightened.
Also, make sure that the end of the set screw and the end of the thumscrew are flat - no burrs or scratches. The end of the thumbscrew screw has a small cap on it that can bind and twist at the blade. Check to make sure it rotates within the thumbscrew.
If your set screw doesn't stay in place when you adjust it, invest in some blue locktight. That will hold it in place but will break free when you adjust it.
Rick Hutchinsons site has a lot of information about the D788, it is where I learned the most about maintenance for my saw -- Rick's Scrollsaw.
Good luck
Tony
The good woodworker does not craft the wood for honor. He uses his craft to honor the wood.
+1 on NC Scroller's suggestions. I would add that on appropriate patterns stop using the grey as it would make it easier to copy.
It says a lot if Fox Publishing does not comment on an issue like this. Even if they said they are aware that people have concerns and are looking into it...
Here is the thread from when I was building it. I gave up trying to post photos on this forum. After they updated to the new format it no longer automatically resizes photos like it use to, I know I could resize everything on my own but the forum isn't as active as it use to be so why bother.
