Bought my 788 in March of this year. I noticed today that the edges are beginning to rust. It hasn't been exposed to any weather nor scratched / damaged. Would this be a warranty issue I should call them about or take it back to the seller? I wouldn't think she would rust much less in 6 months time. Anybody else have this kind of trouble or heard of it?
788 with rusting on top
Its a cast iron table, it will rust just from the moisture in the air. I think Dewalt would laugh at anyone claiming that as a defect. If your table is flat (check it with a straightedge), keep it, if your table is not flat, try getting a new one because of the flatness, NOT because of surface rust. For the rust, give her a good rubdown with steel wool and or 400 grit sandpaper. Blow and wipe off the dust. Wipe the table edges and top with rubbing alcohol, and that will dry in a few seconds. Then (the most important part) apply a coating of a NON silicone containing wax. I use Johnsons paste wax. Every once in a while, rewax it. DaleDale w/ yella saws
I purchased my DeWalt in April of this year, and am experiencing the same problem, the location of my rust area's are primarily on the table top where my arms or wrist rest as I am guiding the projects with my hands. Roughly in the 5:00 and 7:00 o:clock postions.
Just follow Dale suggestions and all will be well!Bill
DeWalt 788
aut viam inveniam aut faciam
Had mine since March, same scenario as Bill, same solution as Dale, although the rubbing alcohol is an excellent idea that I hadn't heard of before
Thanx Dale...~Robert~
DW788 and Hawk 226
Theresa and Marsha, try applying some paste wax to your table whether there is rust or not. The wood will slide much easier on it. I have never had a rust problem either but still apply Johnson's paste wax every month or so.
Mick Delta P-20Mick, - Delta P-20
As Dale said, the rust is the result of the relative humidity in the area where the saw is located. Even those who have commented on rust spots where their wrists rest on the table are probably experiencing higher humidity than ideal. Higher humidity, more persipiration and it won't evaporate, so it stays on the table and allows it to rust.
Tools with cast iron tops aren't coated or painted from the factory (at least not with anything you want to leave on) and unprotected are very vulnerable to rust, maybe even more so than other unpainted metal surfaces. So it's up to you to take care of the rust, but more importantly try & improve the conditions in the shop. I realize that isn't always possible, especially in garage shops. I use a dehumidifier from May to October in my basement and during cold weather, I primarily heat with wood/coal, so I have no problems with any rust. I've had my DW788 for a couple years now with no rust at all. However, coating with a non-silocone wax is a good idea anyway. It helps the wood slide much easier on the table. I do it with all my metal/cast iron tool table tops.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
I have had my DeWalt for 9+ years and also live in South Carolina (very Humid) conditions. Your DW788 is rusting on the edges because of your arms and wrists touching the surface there as was said previously. My tablesaw top (cast iron) and bandsaw table (cast iron) also rust. I use a product called TopSaver to remove the rust, but, it will still rust again.
Two other suggestions: If you cover your tabletops with an old bedsheet, between uses it will not rust where covered even in a humid garage. I have proven this when some areas of the table were not covered with a sheet.
Another tip is if you store "slightly used" scroll saw blades in the open air they will rust. This will not effect the blades cutting ability, but, will rust stain the first inch of wood that you cat.
I call this "Rusty scroll saw blade season".
Originally posted by Mick WalkerTheresa and Marsha, try applying some paste wax to your table whether there is rust or not. The wood will slide much easier on it. I have never had a rust problem either but still apply Johnson's paste wax every month or so.
Mick Delta P-20
Theresa
I have only had my Dremel a few months but I have an idea that I won't have the problem many of you are experiencing. My wrists and hands hardly ever make anything more than momentary contact with the table top. I'm sure we all have different styles but I have an idea that the people that haven't had the problem also don't rest their hands or wrists on the table. I was thinking about that while sawing this afternoon. The times when there is no wood to place my appendages on, I keep my wrists suspended a little. I assume that the humidity coupled with the perspiration or oils in the skin, are what's doing it. Just my thought. You're welcome to take it with a grain of salt, of course.
Originally posted by Minnesota scrollerYou're welcome to take it with a grain of salt, of course.
Threresa
It's environmental
The problem doesn't lie with resting the wrists and hands or not.
It depends on the environment.
I experience rust on my table saw, pressdrill, bandsaw and DW788. And the DeWalt is the least expensive of these items.
I also have rust on my engineer squares and other hand tools.
I have to do maintenance on all of them, and I also need to get a de-humidifier for the shop.
So Metal and moisture in the air = rust, it's as simple as that.
Oh, and by the way, the reason some experience rust where they rest their paws is known as sweat(yea, yea, I know : girls don't sweat) and if you don't want to believe it's sweat then tell yourself that the skin is trapping more moisture in that area causing it to rust faster.
You'll experience the same problem if you leave items lying on top of the table that could trap moisture.
So... What has been said about sanding, cleaning and waxing as well as using protective products that contain no silicone (very important) such as T9 or TopCoat is very good advice.
And preventive maintenance helps. Don't wait till your table is pitted by rust to take care of it, and you'll have tools that will last a long time.
Regards,
Marcelhttp://marleb.com
Reply to Harbor Fraughtby RolfI did not read the fine print, actually not that fine. when I went to buy my new compressor for 25% off (not). That would have been nice, but I am still happy with my purchase. Although I have not used it yet as my garage is rather cold.
7 deg this morning 50's tomorrow-
Today, 09:22 AM -
Reply to Harbor Fraughtby JimernSome manufacturers will restrict items for resale to a certain price or basement price. And in some cases will only sell with the agreement of no discounts allowed.
And then there is margin, the retailer needs to make a certain amount of money on all sales.-
Today, 09:20 AM -
by RolfHave you had big temperature swings in the shop? My first thought is something binding. I fix all of my own stuff and don't hesitate to take things apart to try and isolate where the issue is.
That said at only two years old I would contact Denny and see if he can direct you to a Pegas tech center....-
Today, 09:15 AM -
by NC ScrollerWelcome. Could be a number of things. I would call Denny at Art Crafters of Dayton or Ray at Seyco. Both numbers can be found on the internet.
Today, 06:47 AM -
