Foot switch for Dremel 1680?? & more
  • Foot switch for Dremel 1680?? & more
    I've cleaned up my very old Dremel 1680 (which had very little use). And, want to build fretting and scrolling skills. I have a foot switch (off / on) that I can plug the Dremel into. Is that a helpful or harmful idea? Will this saw run ok like that? Is it better/worse for learning?
    Also, I have it setting on a very stout table. Is it better to bolt it down or just let it sit on the table?
    I'd rather not upgrade yet as I see there are a lot of folks using Dremel in the poll "What scroll saw are you using". Not sure what model(s) are in the pool. I could upgrade if that would help a lot in learning.
    Thanks,
    Regis
    An old beginner leaping in.
    Pleased with my new EX-16.
    I would bolt it down. Using a foot switch has proven very valuable for myself and quite a few others on the forum. Most important thing about scrolling is to just have fun.
      I have a EX 21 and I use a foot switch. You have to hold it down to make the saw run and as soon as you let your foot off of it the saw will stop. This is helpful to me not to have to let go of the board to hit the switch on the saw. I have just gotten into the hobby this summer and having a great time with it.
        I use one from Lee Valley it is very good, I also have one to start my dust system.
        Foot Switches — Air Actuated - Lee Valley Tools
          Thank you. I'll bolt down the saw and hook up the foot switch.
          Regis
            I have a foot switch on my EX-21. It came with the saw and I never thought I would need one. After I used it once, I do not know how I got along without it. It took about 10 minutes of practice to get used to it, meaning going for the on/off switch as opposed to just lifting my foot. I love it.
            Mark
            Proud new owner of an EX-21
            WWW.MGMWOODWORKS.COM
              I have the type of foot switch that you step on to turn on then step on again to turn it off. I have it mounted on the front of my saw stand at knee height. Just bump it with my knee to turn the saw off or on. I have tape over the saw switch to keep the saw dust out.
              Mick, - Delta P-20
              • Jim McDonald
                Reply to Demo display
                by Jim McDonald
                If you just do a Google search for 3d reindeer ornament, you should get several choices....
                Today, 03:41 PM
              • Jim McDonald
                Reply to Woodgrain Worked Against Me
                by Jim McDonald
                Woodgrain is like a straw sucking in the pigment, but I think you did a good job on a complex piece. Lots of patience for this pattern.
                Today, 01:42 PM
              • Rodney Brown
                by Rodney Brown
                Thanks Rolf,
                I actually tried painting the inside of the cuts before removing the pattern and tape. I initially used packing tape because I was out of painters tape. When I sprayed the cuts, apparently the paint bled into the fibers of the wood. But I have to say I have been redeemed by my wife....
                Today, 12:56 PM
                Nice project, I really like the design. You did use a tough piece of material, I would normally suggest cutting at least 3 layers of 1/8 BB because you will get requests of them. I am curious as to why you got some black bleeding into the grain? Is this mounted on a black backer ?
                Today, 08:56 AM
              • Rodney Brown
                by Rodney Brown
                This is my latest project and I'm still up in the air about it. The wood was reclaimed from a table that someone had thrown away. It is 3/4 MDF with veneer on both sides. The project is 11 x 14 and is pretty heavy. The pattern was from "Grandpa" and I believe his real name is Paul. I used...
                Yesterday, 09:31 PM
