Hello all first time post maybe someone can help have a delta p-20 40-680 scrollsaw for some reason upper arm wont go up and lock in place anymore as in the case like when you break a blade its suppose to catch has anyone had this problem? any help would be appreciated
delta p-20 scrollsaw
rawcut, I have a large rubber band running from the upper arm lock lever over to the lockdown handle for the hold down foot rod.(Which I removed) That way the upper arm does not get locked up when a blade breaks. The upper arm on my saw stays up on it's own without the arm lock. This is about as clear as mud. I top feed and whenever I open the bottom blade clamp to change holes I just push the arm and blade up and then down for the blade to go into the next hole I want to cut.Mick, - Delta P-20
Yesterday, 10:53 PM -
Yesterday, 10:43 PM -
Yesterday, 01:10 PM -
Reply to Hello from Central Floridaby meflickWelcome to the forum from another Tennessean....
Channel: Welcome Members
Yesterday, 01:04 PM -
Reply to Hello from Central Floridaby John SmithThanks guys, I have a lot of HDU left over from my sign business in various thicknesses.
HDU doesn't "fuse" or repair itself under heat or friction. Only acrylics and some PVC materials do that. Depending on what part of the world you are in, you would have to google HDU Distributors...-
Yesterday, 10:01 AM -
