I've used a Dewalt DW788 for several years, and wore it out. Bought a used Hegner Multi-Max 18 that I've upgraded to current specs, but am not real pleased with. Before I haul the Dewalt off to the repair center, I've located a Q3 that I can buy for $125. I had a P-20 once, and didn't like using it due to the difficulty in clamping the blades in the swivel type clamps. So...what I'd like to know is, your honest opinions of the Q3. I do quite a lot of stack cutting; I prefer to build larger clocks and other bigger projects, and I use almost 100% hardwood that I've bought from the mill and dried in my barn before processing into usable lumber. I already know Rick's opinion, and am about ready to buy the machine based on that. Thanks everybody.
Delta Q3 Users Opinions
I have used my Q3 for 12+ years and love it. It has only 2 drawbacks as far as I am concerned. 1. because it only bottom feeds, I am limited to approx. 10" x 10" pieces or smaller if I have to get to fret holes in the middle of a board with a thin blade #2 or smaller. 2. I keep a supply of mini-switches on hand since they seem to go after only 1000-1500or so on-off cycles.
george
George
delta 650, hawk G426
I have had my Q3 for about 22 years and still love it. I have worn out a couple of on/off switches also but do not understand why sawdustus is limited to a 10" square. Mine is 18" saw and I have done a many 30" panels on it over the years and some larger by turning the blade around backwards and bringing the wood towards me as I cut. I do not recommend to much of that style of cutting but it works in a pinch. Steve
Steve, that's because I have not turned the blade around. I have enough trouble cutting when I can see the line in front of me. What I meant by 10 x 10 inch was if the center holes are more than 5 - 6 inches in from the edge of the board it is difficult to thread really thin blades: they bend too much and like to snap. I use my Hawk, a top feeder, for really large and/or more delicate cuttings in thin wood.
George
Thanks again Scott. I really appreciate your generous offer. After a couple of months of very frustrating attempts trying to solve the Hegner blade breaking problems, and considering all the problems and expense associated with the purchase of a used saw, I finally loaded the DW788 in the truck and took it to the Dewalt Repair Center in Charlotte last Friday. The Guaranteed Total Rebuild price of $259.99 suddenly appeared to be the best solution to the whole problem. So far, by trying to come up with a good, working scroll saw, and save money, I have spent over $800 and broken dozen of blades. I am still trying to solve the Hegner problem, taking into consideration every possible scenario that may cause the arms to be misaligned. Drs. appt. @ Salisbury V.A. today, so won't get into it much until tomorrow. Another lacking of the Hegner is the very small table. Working on a pair crosses by Dirk Boelman that are cut from 3/4" stock and 10 x 18 board. Board will fall off table if I don't hold it while rethreading the blade, and have to be real careful when cutting at the extreme ends that the board doesn't tip.Manufacturer Of Heirloom Quality Sawdust
Bruce,
as to the tipping could you add an auxiliary table top. perhaps a 1/8" sheet of plexi or even plywood that has double sided tape under it to make your table larger in area? I think that would work well to stop the tipping of the wood due to small area of the current table top. 1/8" ply or plexi would not change the use of the blade that much. I'd give it a try."Still Montana Mike"
Originally posted by sawdustus View PostSteve, that's because I have not turned the blade around. I have enough trouble cutting when I can see the line in front of me. What I meant by 10 x 10 inch was if the center holes are more than 5 - 6 inches in from the edge of the board it is difficult to thread really thin blades: they bend too much and like to snap. I use my Hawk, a top feeder, for really large and/or more delicate cuttings in thin wood.
george
Thanks for the suggestion Mike. I have considered adding an auxillary top, but the focus has been on correcting the cause of blade breakage. Yesterday, I couldn't cut 5 minutes per blade before breaking, always inside the bottom clamp. Something is seriously out of line. I bought the saw from an elderly widow lady who knew nothing about the machine, except her husband used it. I am going to check the arm mounts and spacers next. Perhaps the late former owner had taken the machine apart and reassembled it improperly. Maybe the car ran into it; it was in the garage. I don't believe it was used much by the last owner due to the books and patterns she gave me. They were all beginner prctice paterns.Manufacturer Of Heirloom Quality Sawdust
Hi, Sawman. I started out with my Q-3 & really liked it. Then I started using spiral blades & it was almost impossible to clamp those twisted blades tight enough to hold. If I set the clamp loose enough for the blade to insert, it would not clamp tight, & when I tightened it up enough to hold it, I could not get the blade into the clamp. Sooo, I bought my 788. Otherwise I liked the saw & still have it. I use it once in a while when I use flat blades. Hope you can work things out OK. Good Luck.PERK
Reply to YoraHome Laser w/CNC Engraver/Routerby RolfTony have fun, There is a great lightburn forum on face book also for Orture I would assume. What size did you get?
Linda, With the laser engraver I just jumped in and then realized I had bought something that was very limiting and started to research after the fact. I know better, but...-
Today, 10:02 AM -
Reply to Spring Issueby will8989Bruce wishes I was less challenging.
Channel: Publisher Feedback
Today, 09:42 AM -
Reply to What is it?by will8989Good guesses, but no. It’s very useful and “outside the box.”
Today, 09:39 AM -
Reply to What is it?by RolfMy first thought is to hold the small paint bottles, but the holes are not symmetrically spaced....
Today, 09:31 AM -
Reply to Spring Issueby RolfI am of the older crowd, LOL , I was blessed with a father, old world German tool maker and a Mom that turned into a techno junky. She got into computers in her mid 70's and digital embroidery, started digitized music that she played using computer software. she was a seamstress, by profession.
Today, 09:29 AM -
