Hi, I bought a used delta 40-601 last night for my son. This afternoon he had it going at low speed and was playing with the blower hose plugging it with his finger and the machine shut off and will not start. Any suggestions?
Couple things to try. #1 check to see if the unit has a circuit breaker or fuse that popped. #2 Assuming you have access to an air compressor trying blowing the switch out. There might be a heavy coat of dust in the switch. #3 check the power cord for breaks or a bad connection. #4 check the brushes on the motor.
After a lot of misleading communications the Mexican government seems to be finally getting it's act together. I was just sent a bulletin inviting me to present myself at a vaccination station this coming Wednesday.
Still no idea of which vaccine I'll be getting but if it's the Russian...
Nice job Alex ! I am discovering that Yin Yang sign , which is beautiful.
I am not yet as fast as you on the scroolsaw.... but it's coming!
And you seem to have quite a big amount of patterns !
I will keep in mind....
