Squaring Blade Holders
  • Squaring Blade Holders
    I came up with a simple and easy way to square the ends of the blade holding screws on my DW788, after experiencing a lot of blade slippage and breakage awhile ago. I took a block of hardwood and made sure it was squared. It can be rectangular, just as long as the faces are all squared. The clamp screw on the DW788 is 7mm, so I drilled a 7mm hole in the block, also at a 90 deg. square angle, through the block. The screw should turn into the hole, as if its threaded, and the block thin enough on that plane to allow the screw to extend beyond the block face. Making sure the table on my disc sander was at 90 deg. square, I placed the block on the sanders table, which held the screw in a horizontal plane to the disc face, and then dressed the screw end. You could even use the miter square to further insure everything is squared while dressing. This worked better for me than free handing, and eliminated the blade breakage I was getting. This method should work for any blade clamp screw by drilling the hole the proper size for the screw. Also, on a new blade, I keep an emery board, or a small sanding block near the saw, and sand the ends of the blade to remove any residue from manufacturing to give the blade a better grip and prevent slippage. I hope this is clearer than mud!
    Excellent tip! Thanks for sharing.
      Thanks for the tip!
      Dan in So.Ca.
      • Quartz43
        Reply to My computer issues.
        by Quartz43
        Glad things worked out.
        I just updated my older PC. The hard drive was 500 gb and eight years old. I cloned it to a one TB SSD (solid state drive). Put the cloned drive in and worked perfectly with all my old programs. The computer is now much faster. The new drive was about $100 and...
        Today, 05:02 PM
      • NC Scroller
        Reply to Need suggestions or a bit of guidance
        by NC Scroller
        You nailed it.👍
        Today, 04:03 PM
      • NC Scroller
        Reply to A new toy.
        by NC Scroller
        Once upon a time ( in the 70's) i attempted bow hunting. I believe the bow had a 45 pound draw. I quickly learned that it was not for me. It takes lot of hard work and practice just to be fair at it. Good is a whole different level. I hope you do better than I did.
        Today, 04:02 PM
      • Linda In Phoenix
        Reply to A new toy.
        by Linda In Phoenix
        Now that's a cool way to maintain hand/eye coordination. Enjoy that toy--- and--- HAPPY FATHERS DAY TO ALL THE DADS OUT THERE!
        Today, 01:30 PM
      • Linda In Phoenix
        by Linda In Phoenix
        So glad you are back up and running. You will be awed by the speed of your new drive, fresh drivers, and cleaned up files. Spring housecleaning!
        Today, 01:28 PM
