I own 2 Dewalt 788's and wanted to pass along the following information to others that have one since I've now experienced the same issue on both saws.
I posted a while back ago about the linkage coming apart on the motor cam inside the unit. Well it's happened again, only this time on my other saw. The first time I thought it might be caused by pulsing the saw with the foot pedal but the second saw does not have a foot pedal on it so that blows that theory.
For those of you that hear the knocking noise it might be worth the effort of taking it apart to check this connection. This saw had started knocking for a week or two prior and I tried turning the tension rod as shown on Rick H's site. It quieted down a little but then the connection came apart and wouldn't cut. My son was using it when he came to me and said the blade was vibrating but not cutting. Upon taking it apart there was the screw and washer sitting inside with the linkage sitting loose. Not easy to get back together but once done it runs like a top. I'm thinking a little loctite would have been a good idea but if it happens again I'll try and get some on it. Hope this might help someone else should they run into it.
