And I'm a bit curious, if anyone else has had a similar problem.
While I was working on a project this morning the blade tension mechanism on my saw let loose. No!! I don't mean the blade came loose, I mean the whole mechanism came loose. The saw started making a grinding noise and the tension on the blade was gone. I tightened the blade holder again and started to cut and it happened again, I actually watched the tensioning lever work it's way loose.
I removed the cover and underneath was a large bolt holding the mechanism together. Once I removed the bolt and the lever, I could see some ominous metal shavings and I wondered if I would need a new tensioner. I gave the tensioner a good cleaning, and removed the shavings, when I looked closely at the bolt, I could'nt see any wear. However there was quite a burr around the hole where the bolt came out, so I sanded that down and cleaned away all the shavings. I re-assembled the mechanism and tightened the bolt and everything seems to be working OK for now.
I had noticed prior to the grinding noise, that the tensioner was getting very hard to move.
Has anyone else had an issue like this?
Marsha
Marsha
