How can I keep the tension on my pin less blades ? It keeps comng loose at the lower clamp.
Roybi 16" scroll saw
I am not sure on the 16" but on my 18" I took sandpaper and sanded inside the clamps. There were some burrs left there during the manufacturing process.
Once they were gone it was much better.
note. I still do have a problem clamping extremely fine blades. less that 0/2.
I have to admit it is a short coming of the blade clamp designCAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
I have found that over time my bolts on my Royobi seem to wear unevenly if I don't get the blade exactly centered in the clamp I have had to refile my bolts a couple of times top and bottom it seems there should be a way to redesign the bolts?Daryl S. Walters Psycotic scroller with a DeWalt 788
Mine does not use bolts for the clamping. I will take a picture when I get home and post it. The clamp looks more like the jaws of a pair of pliers with an adjustment screw behind the fulcrumCAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Reply to More Miniature Birdhouse Ornamentsby Sandy OaksThanks Pete. Yes, down to only one on the tree....Today, 11:41 AM
Reply to More Miniature Birdhouse Ornamentsby Sandy OaksThanks Rolf. Yes, fun cuts....Today, 11:41 AM
Reply to Koi fish (Yin Yang symbol)by planeurNice job Alex ! I am discovering that Yin Yang sign , which is beautiful.
I am not yet as fast as you on the scroolsaw....but it's coming!
And you seem to have quite a big amount of patterns !
I will keep in mind....
planeurToday, 10:38 AM -
Reply to More Miniature Birdhouse Ornamentsby scrollerpeteTime to replenish your display Denny? Nice cutting as usual.Today, 10:09 AM
