Working for wood, I forgot that I also had problems with my blade clamps separating. The clamp shells look like they are made out of aluminum or pot metal and held together with 2 4-40 screws.
I am a bit heavy handed and the thumb screws give you a good grip. So eventually I striped the small threads and clamps started to split.
To solve the problem I took all off my clamps apart drilled out the threaded holes and put heli-coil inserts in the holes and used good quality 4-40 allen screws in place of the ones from the factory.
I haven't had a problem since.
