Delta Model 40-601
  • Delta Model 40-601
    I have this saw which is not running. Has circuit board problem I expect.
    Delta does not have replacement part. Does anyone know of a solution? Can the circuit board be repaired or can I get around the board and run in single speed?
    tem1998
    You find something here.
    http://www.acetoolrepair.com/
    Delta P-20 & Q-3
      Tem;
      Here is a place that I got lots of help from one time on a tool that was outdated and eventually got my parts for it.
      http://www.owwm.com/
      You would have to click on discussion forum at the top and join to participate but I believe you would get lots of help there.
      OH my gosh. I just mentioned going to another discussion board to get some additional answers to a question. I hope I don't get jumped on this time. I was only trying to be helpfull in both cases.
      good luck in finding a replacement circuit board. There just might be someone there that has a good used one for you.
      W.Y.
        Originally posted by William Young (SE BC)
        Tem;
        W.Y.
        Thanks Bill, thats a great link you gave there. an no you are not in trubale for adding a link. only when you jump on someone for not doing it. you was helpfull. thanks.
        Evie PS you told me to get over it, now its your turn to get over it. let it ly
        • planeur
          Reply to A Bear In The Woods
          by planeur
          Trรจs beau John and original !๐Ÿ˜Ž Like it very much, and cherry is the perfect wood for a bear.....!๐Ÿ˜‰๐Ÿ˜
          planeur
          Today, 06:59 AM
        • Jimern
          Reply to My computer issues.
          by Jimern
          Worth a try, but very rarely works. During the install in windows, the software registers links (for want of a better word) which are required for it to operate. install is what is needed...
          Today, 06:51 AM
        • handibunny
          Reply to New turning tools
          by handibunny
          Looking forward to seeing what you come up with. Your work is always a treat to look at!
          Today, 05:34 AM
          I clean it up and stuff regularly. If I do a lot of typing, spreadsheets, etc., I use the computer as itโ€™s faster for me but take the tablet to shows and markets to post from there. I also use my rapid resizer program on the tablet when I want to change a pattern and am downstairs. I really need a...
          Yesterday, 11:16 PM
        • Linda In Phoenix
          by Linda In Phoenix
          Yesterday, 05:55 PM
