Since the hurricane supplied me with lots of material, I have decided that this is the time to take up 'bowl carving' but where do I find information on drying this Maple wood and what sort of sawing is needed to keep it from checking and cracking ?
drying maple wood for bowl carving
Re: drying maple wood for bowl carving
Barbdoor, (sorry you didnt post your name)
You might first start by cutting the logs in half this will elliminate some of the cracking. If you have ever looked at a log when it is dying you will see that the cracks always start from the middle of the log. This is because wood always drys from the inside out. If you want to carve bowls then you could have it kiln dried this will speed up the drying process and elliminate more of the checking. I have also had good luck by hollowing out the middle of the log. If you are going to carve the bowl over time put it into a garbage bag until you are ready to carve again. Once the bowl is finished seal it and apply the finish. My final tip is while it is dying place it on four dice this will allow the air to cirulate around the piece.
I am not an expert but these are some of the things that have worked for me.
Colin
Sorry this is so late, but if you want to turn from the whole cross section of the log, try that Pentacryl liquid treatment....it's supposed to eliminate the checking and splitting of green wood wen you work it. I've never tried it but have read quite a bit, and someday I will give the stuff a go. sounds like an interesting product.
Al
Reply to Question about tilting head sawsby hotshotI'll talk about this specific "slice" of your question. Most Tilting head saws do come from the same Taiwan factory, except Excalibur. So what happened with Excalibur was . . . General got bought by a Chinese investor, some China/Taiwan drama ensued, EX manufacturing moved to China. That...
Channel: Welcome Members
Today, 04:41 PM -
Reply to Basket C15Did this thread get hacked? That is a very strange sidetrack from KyivWorkshop.Today, 04:21 PM
Reply to Question about tilting head sawsby handibunnyIt doesn’t matter whether the saw table tilts or the saw arm tilts. Either can be used for any project cut at an angle, and there’s a learning curve for each.
I actually prefer the tilting table because the blade remains vertical. I find that at really steep angles, like 40 or 45 degrees,...-
Today, 02:10 PM -
by will8989This is the tapestry I found in the cedar chest. We can’t identify where the pictures are from. Two among many. I also forgot to mention dad was also in the army Fife and Drum Corps and also played with a big band when he was discharged. Have to find that info....
Today, 12:34 PM -
Reply to Bruce doing greatby will8989What a morning. The therapists were quite pleased with what he could do. He took the wrap off today and he can walk with the walker with very little pain. It’s getting the leg completely straight that is hard to do. It’s when his brother stopped in that things went off rails. Rolf, we are talking...
Today, 12:19 PM -
