I have a 1985/87 delta 18"scroll saw 40-601 with a burnt pc board in control panel. Was told by delta part is no longer made. Any suggestions on how to save the saw?
need help with a delta scroll saw control panel
Can you still identify the component part numbers? Is it a single side board or multilayer board? I have have rebuilt them in the past (never a saw controller) with hard wire and replacing the burned components. Is it variable speed ? I wonder if a newer speed controller can be addapted? Do you have a schematic?
Sorry my Mr Fix it mode kicked in.
In reallity I would toss the saw and Buy a new one, I dont have time to fix anything anymore.Rolf
Reply to New Toy!by RolfQuartz I only bought the air filter, That same model is sold by many distributors, I see Grizzly has it and several others. I was going to build one but this thing works great. I will get a charcoal filter for it also. Great when doing Pyrography. They also had a Pfingst brand flex shaft tool I haven't...
Today, 07:50 AM -
by will8989Carole, only you would cut sprinkles on a scrollsaw. I would probably use rice and stain it. I just gave up replacing my insert. Its worn, but works for what I need. I do sand it to make sure there are no burrs sticking up to scratch the wood. I will be trying the new contact paper when mine runs...
Yesterday, 08:16 PM -
Reply to Shawl pinsby will8989Thick hair would need a larger opening, thinner hair would require a smaller opening to stay in place. The one being shown in the utube would probably work for thicker hair. They look way better than a pencil or dowel! That elephant sure is cute in her hair!.
Yesterday, 08:09 PM -
