Saw storage ?
  • Saw storage ?
    Due to time constraints, most of us can't get to the saw each day (and for me, haven't gotten to it yet!). So I wanted to know, when the saw sits idle, should the tension on the blade be released, reduced, or maintained? I know my bandsaw needs the tension released in order to prevent damage to the wheels and blade, curious if the scroll saw was similar.
    Thanks!
    Draken
    I always release the tension when I'm going to be away for any amount of time.
    Bill
    DeWalt 788
    aut viam inveniam aut faciam
      I always release the tension. It takes the pressure off of all the bearings, springs etc.
        Boy, you sure do learn something new every day.
        The last few times I've used my saw, when I had finished, it was an inside cut, so I just never re-inserted the blade.
        Never thought of releasing the tension, but now I'll make a point of it. It sure makes sense.
        Kelly
          Draken, I always release the tension when I am done with the saw for the day as well as giving it a good vacuuming. Mick P-20
          Mick, - Delta P-20
            Thanks
            everyone for the replies. Releasing the tension is what I figured, for the same reasons that the bandsaw needs to be detensioned.
            Cheers,
            Draken
