Question for Dewalt owners, I purchased a flexable lighted magnifier and am curious as to how others who have or use one attached it to their saw or stand? Placing it on my stand seems the most obvious due to the excessive weight it would place on the upper arm if located there. Any suggestions....
Lighted magnifier placement
I made an auxilary table that bolts to the frame of the saw's table and sits to the side. I made it so that it holds tubes for blades and has room to put other things while I am using the saw. The light bolts to the back of the table. I will take a picture and post later.Dan
I have my magnifier attached to the back of a cabinet sitting next to my saw.
The only thing to be careful of is that the arm of the magnifier/light doesn't interfere with working with large pieces of wood (if you do large projects). You can place the light almost anywhere if you generally work with small projects.
My advantage is having my second saw on the other side of that cabinet, so I can swing the magnifier/light from one saw to the other without having to reposition it.
Thanks for the replies, I was thinking of something along the lines of what you described Dan, I'm limited on space in my work area and really have no place to attach it other then the stand, I'd like to see the pictures of your auxilary table, sounds like a winner to me.Bill
DeWalt 788
aut viam inveniam aut faciam
pictures
Here are a couple of pictures of the table I made.
What I would do differently.
1. Make the table wider.
2. Make it deeper so that it comes closer to the front of the saw.
3. Put a leg support on the end that hangs over for more stability.
Good luck!Dan
Looks good Dan, pretty much what I had invisioned doing myself. Thanks for posting your pics.
Dale, somehow I would expect that from you!Do you have a yellow car too?
Bill
DeWalt 788
Reply to What do you think?by vgrafI have a VacuFlo system for my house. It might have enough suction for a small table saw but not for the large cabinet makers saw like you have.
Like the others have said, your Walvac might work fine for smaller tools, especially for a hand sander.
The VacuFlo actually uses...-
Today, 02:20 AM -
Reply to My lucky day!by vgrafI got my second shot last week here at the Eisenhower Med Center in Palm Springs. I am 82 and in their system and was contacted by them to come in for my first shot. At the completion of that shot I was given my appt. for the second shot.
Like yours Rolf they were really organized both times....-
Today, 01:56 AM -
Reply to Another Mid-Michigan Scrollerby dgmanGreat looking work Jeff! Welcome to the forum from Southern California!
Channel: Welcome Members
Yesterday, 11:57 PM -
Reply to My lucky day!by dgmanMy wife and I got our second shot two weeks ago, we’re done!
Yesterday, 11:50 PM -
Reply to What do you think?For something like a table saw the volume of air moved is much more important than whether a good vacuum is produced....
Yesterday, 08:57 PM -
