I have a Delta Scroll Master and I love it, but I would really like to make the blade removal easier. As it is I need to insert a post/hex key thingamajig. Does anyone know if they have re-designed the blade holder to a hand screw clamp? Am I able to do this? It would make life so much easier is I wasn't messing with the "key" every time I needed to reposition the blade.
Modify my Delta?
Yes:
If your saw is less than about 12 years old, there is an upgrade called QuickSet II. Delta part no. 40-251. Some older saws, the QuickSet II only fits the upper arm due to clearance problems under the table.
Try searching at Amazon.com under Tools and Hardware for: 'QuickSet II'
Aside: takes above average mechnical skill and knowledge to remove and install the new blade chuck. You are your own judge on this.
Phil
by NC ScrollerGlad you got it worked out. Happy endings are always the best. Can you post a picture? It might be helpful to someone else in the future....
Today, 03:44 PM -
Reply to Minor Question About Bowlsby scrollerpeteIf the bowl is not used for wet stuff you can use Titebond glue that dries up invisible. My trick is after applying the glue and I used my bowl press from Carol, after a few minutes, release the press and use a plastic straw cut at an angle to remove the excess glue.
https://www.leevalley.com...Today, 02:08 PM -
by RoyzMGThanks for the comments. I finally designed my own tool that works great.
Today, 01:16 PM -
by RoyzMGI'm just beginning to try my hand at bowls and I've been following Carol Rothman's book on scroll saw bowls. I'm on my second bowl and now understand why you need to sand the inside before attaching the bottom ring. My question deals with gluing the bottom ring. It appears to be very important to...Today, 01:15 PM
Reply to Bigger Projectsby Chance13I have a 20" Delta that I made Judy''s "Hidden Forest" with. Took me all of 9 months of trying to find the right wood,etc.
You could use a 16" saw as you can break down the pattern and pieces into smaller sections.
I won a best of show ribbon with it.
Excuse...-
Channel: Beginners Scroll Saw
Yesterday, 12:57 PM -
